Error message filling the log
  • Error message filling the log
    Every few days my log gets filled with these error messages. I can restart the plug-in and they stop for a few days, then come back. There is nothing in the HS log that to indicate a cause when the errors start and the HS devices continue to reflect energy consumption.
    What can I do to troubleshoot?
    Sep-28 1:49:22 PMInformationalBrultech ECM Device connection established to COM:11.Sep-28 1:49:22 PMPlug-InFinished initializing plug-in UltraECM3Sep-28 1:49:19 PMInfoPlugin UltraECM3 has connected. IP:127.0.0.1:63816Sep-28 1:49:12 PMInfoPlugin UltraECM3 with instance: has disconnectedSep-28 1:49:12 PMPlug-InShutting down Plug-In: UltraECM3Sep-28 1:48:53 PM1ErrorSystem.OverflowException: Arithmetic operation resulted in an overflow. at HSPI_ULTRAECM3.Channel.processWattSeconds(UInt64 wattseconds, Int64 seconds)Sep-28 1:48:53 PM1ErrorSystem.OverflowExceptionSep-28 1:48:23 PM1ErrorSystem.OverflowException: Arithmetic operation resulted in an overflow. at HSPI_ULTRAECM3.Channel.processWattSeconds(UInt64 wattseconds, Int64 seconds)Sep-28 1:48:23 PM1ErrorSystem.OverflowExceptionSep-28 1:48:22 PM1ErrorSystem.OverflowException: Arithmetic operation resulted in an overflow. at HSPI_ULTRAECM3.Channel.processWattSeconds(UInt64 wattseconds, Int64 seconds)Sep-28 1:48:22 PM1ErrorSystem.OverflowException
    HS3 Pro Edition 3.0.0.548
    What Brultech device and firmware are you running? What type of com port are you using?
    Ultrajones
      It's an ECM-1240, about 4 years old. I'm not sure how to check the firmware, but it hasn't been updated since I installed it.
      The link is serial to usb converter.
        When this happens again, please enable debug for about 30 seconds before you restart the plug-in. Send the debug file to ultrajones@hotmail.com before you fire the plug-in back up because you'll overwrite it.
        Ultrajones
          I thought it might have magically fixed itself, but the errors returned. Debug log attached.
            Channel 6 Watts is reporting: CH6 Watts=NaN. I'll have to dig into this a bit further.
              The issue appears to be isolated to your ECM 1240 channel 6. How do you have that channel configured?
                Channel 6 is set up to monitor HVAC with small CTs: furnace, boiler, A/C. I think there may also be a circuit that has a dehumidifier on it, but I'd need to check more carefully to be sure. It's been several years since I paid any attention.
                AFAIK, it's not set up any differently than 3, 4, 5, and 7.
                Unconfigured PHP Module
