UltraECM3 HSPI for HS3
This topic is closed.
This is a sticky topic.
  • UltraECM3 HSPI for HS3
    Description
    UltraECM3 is a HomeSeer3 plug-in for the Brultech Energy Consumption Monitors (ECM). The plug-in connects directly to one or more Brultech ECM devices providing HomeSeer a view into the electrical power consumption of your home.
    The Brultech ECM-1240 and GreenEye Energy Monitors are multi-channel energy consumption monitors designed for use with residential electrical systems. The ECM-1240 is used to measure consumption of up to 7 electrical circuits and provides up to the minute consumption data. The GreenEye Monitor (GEM) is used to measure consumption of up to 32 electrical circuits and provides up to the minute consumption data. The GEM also includes 8 temperature sensing and 4 pulse counting inputs.
    How It Works
    The UltraECM3 HSPI connects directly to the Brultech Energy Consumption Monitors using either a serial or TCP network connection. The packets received from the Brultech ECM devices can be buffered and averaged to reduce loads for ECM units configured to send frequent updates. The UltraECM3 plug-in provides real-time access to Watts and KWh. The plug-in allows you to create a HomeSeer device for just the ECM devices you want HomeSeer to display and react to.
    • Support for up to 9 Brultech ECM-1240 and GreenEye Monitor devices.
    • Create only the HomeSeer devices you need to track energy usage in your home.
    • A Loads web page provides access to the real-time energy usage.
    • The Dashboard web page provides a cost and usage breakdown of all electrical circuits connected to the Brultech ECM devices.
    • The Energy Charts web page displays watts and KWh usage over time.
    • Error Try/Catch logic to ensure plug-in doesn't fail with an unhandled exception.
    • Multiple threading allows UltraECM3 HSPI to communicate with the Brultech ECM devices without disrupting the performance of HomeSeer.
    Example Usage
    • Use plug-in UltraECM3 along with the Brultech ECM-1240 or the Brultech GreenEye Energy Monitors to monitor the electrical power consumption of household loads, sub-panels and panels.
    • Generate an e-mail notification whenever the main panel or an individual circuit exceeds a set threshold.
    Version 3.0.6265.19154 - Released Feb 25, 2017
    • Major new release which contains a complete rewrite of the web pages. All web pages now use the HomeSeer jQuery mechanisms.
    • If you're using a GreenEye, you'll need to change the packet format. See this post: https://forums.homeseer.com/showthread.php?t=186987
    • Fixed issue with chart not displaying data beyond 1 day.
    Version 3.0.6678.32449 - Released April 14, 2018
    • New Device Icons
    • Modified root devices so they don't show up in HomeSeer3 event device value change triggers.
    • Minor bug fixes
