I have some of my ECM devices set to 'Hide device from views' for a cleaner devices display. (For example - my air conditioner doesn't need to be displayed during the winter in Minnesota) I set it to be hidden, but it keeps getting reset to unhidden. I assume UltraECM is doing this. Can this be changed?
UltraECM - HS2 keeps making device visible
Dick
HS PRO 2.5.0.81, WinXP, IE8, Shuttle XS35V3, 2.13GHz, 4GB, 40GB SSD drive, AC-RF2, ADIOcelot, Message Server, TI103, SNEVL CID, pjcOutlook, MCSTemperature, Powertrigger, BLBackup, BLFloorplan, BLIcon, BLOccupied, BLRadar, BLRfid, BLLogMonitor, ACPUPSD, UltraECM, WeatherXML & Stipus' script connector. 500+ devices, 260+ events, 1-wire weather station + temp/humidity sensors & Oregon Scientific temp & humidity sensors & 2 Brultech ECM-1240sTags: None
BUMPDick
Hello RAM,
The UltraECM2 plug-in may be resetting the device hidden status, but I am unable to modify that behavior because I no longer have the version of Visual Studio that allowed me to package up the changes into a setup program.
UltrajonesPlug-ins: UltraMon, UltraM1G, UltraCID, Ultra1Wire, UltraLog, UltraWeatherBug, UltraPioneerAVR, UltraGCIR
UltrajonesDick
I no longer have .NET Framework 2.0 installed on my developer system. Do you have .NET Framework 4.5 installed on your HomeSeer system? If yes, I may be able to send you a .exe file containing the fix.
Originally posted by Ultrajones View PostI no longer have .NET Framework 2.0 installed on my developer system. Do you have .NET Framework 4.5 installed on your HomeSeer system? If yes, I may be able to send you a .exe file containing the fix.
Ultrajones
NEVER MIND…. I just found out .Net 4.5 isn't compatible with XP.Dick
