can not find gamepad
  • #16
    That did the trick.
    Now it works.
    • #17
      Big thank you creating the plugin :-)
      • #18
        No problem. Glad it worked
        Cheers,
        Bob
        • #19
          I'm just trying this plugin and had exactly the same issue on WHS 2011 and this also fixed it for me.
          Simon
          • #20
            Hello,
            Although this is an old thread, I just installed the plugin on my HS3/W10 system.
            The USB joystick shows up in the Windows device manager, but not in the plugin.
            I installed directx.
            Anything else I can try.
            Thx...
            • #21
              FYI:
              Transitioning from Hs2 stipus to HS3 Blade plugin
              HS3 / Win 7
              Had same problem as original poster
              Installed the directx runtime as per Blade instruction/link above.
              Rebooted machine.
              Problem solved.
              Andrew B.
              • #22
                Hello Andrew,
                Tried it again and this time it worked! Problem solved.
                Thanks for the reply!
