Error after starting Homeseer
  • Error after starting Homeseer
    Hi,
    just installed the plug-in and when restarting homeseer I get below error:
    Jan-22 11:27:21 Error Initializing plug-in(2): Kinect Instance::Could not load file or assembly 'Microsoft.Kinect, Version=1.7.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35' or one of its dependencies. The system cannot find the file specified.STACK: Server stack trace: Exception rethrown at [0]: at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessag e(IMessage reqMsg, IMessage retMsg) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(Mess ageData& msgData, Int32 type) at HomeSeerAPI.IPlugInAPI.InitIO(String port) at Scheduler.clsHSPI.CheckInterfaces()
    I have SDK 2.0 installed...
    When I launch the Kinect configuration verifier, all boxes have the green check mark, except the USB controller one, this says it did not recognise the USB port, but it might still work.
    At the bottom in the "verify kinect depth and color streams" I see the output of the kinect camera, so it is working.....
    Anything else I need to install/check?
    ow..... just noticed this is only for V1 sensors........
    Guess I will have to source one of those....
      yeah, only Kinect for Xbox 360 is supported
