Kinect Plug-in - Beta Testing
This is a sticky topic.
    #31
    Yes that correct. Updated log
    2013-10-15 14:32:42 Plug-In Finished initializing plug-in Kinect
    2013-10-15 14:32:39 Info Plugin Kinect with instance: has disconnected
    2013-10-15 14:32:39
    Error Initializing plug-in(1): Kinect Instance::HSPI::InitIO: Failed to init: Exception: System.Exception: C:\Program Files (x86)\HomeSeer HS3/html/images/Kinect//zones/zonebackground.jpg at HSPI_KINECT.KinectApp.Init() at HSPI_KINECT.HSPI.InitIO(String comPort)
    2013-10-15 14:32:38
    Kinect DEBUG at System.Drawing.Image.FromFile(String filename, Boolean useEmbeddedColorManagement) at HSPI_KINECT.KinectApp.DrawZonesToFile() at HSPI_KINECT.KinectApp.Init()
    2013-10-15 14:32:38
    Kinect ERROR C:\Program Files (x86)\HomeSeer HS3/html/images/Kinect//zones/zonebackground.jpg
    2013-10-15 14:32:38
    Kinect DEBUG Web Pages Registered
    2013-10-15 14:32:38
    Kinect DEBUG Voice Recognition Initialized
    2013-10-15 14:32:38
    Kinect DEBUG Logger Initialized
    2013-10-15 14:32:38
    Info Remote application or plugin has connected: 127.0.0.1:57503
    2013-10-15 14:32:38
    Info Plug-in Kinect has connected successfully
    2013-10-15 14:32:38
    Info Remote application or plugin has connected: 127.0.0.1:57502
    2013-10-15 14:32:38
    Plug-In Interface Kinect is running as a trial, 25 days remaining.
    Tasker Plugin / Speech Droid
    Tonlof | Sweden
      #32
      do you have the zonebackground.jpg file in html/images/Kinect/zones directory?
      if not, you probably forgot to copy the Kinect directory (included in the zip and containing graphic files) in html/images
        #33
        Just before I read your answer I tried to moved the Kinect diretory to html/images so I think is working now. Thank you so much for the help.
        Tonlof | Sweden
          #34
          version 3.0.0.3 is available from first post of this thread.
          Optional phrases or words, and multiple choices was added to the Voice Recognition syntax
            #35
            will it work with the new zee
            Hi I just purchased the new zee and I am in the process of setting up hstouch and speaker clients for it will this plug in work for remote install for the zee.
            Thanks Ken
            HSPRO,HS3PRO, BLsecurity, , MCSxap, HSTouch Android, UltraGCIR, CM15a, USBUIRT, BLUSBUIRT, WIFIRGB, BLAB8SS, BLcontrol, BLGData, BLLAN,BLOccupied, BLRadar, BLVolume, iTunesDAAP, UltraGCIR3, Airplayspeak, BLalarm, BLbackup, BLLED, BLrandom, BLReminders, BLRF, BL Speech, Hyperion, IFTTT, KINECT, XBMC, MCSprinkers PRO, PHLocation, ULtrapioneer, Ultralog, ultraweatherbug, Z,troller, GC-100, GC WIFICC, GC-WIFI SERIAL, Nitrogen logic depth camera controllers,
              #36
              I don't think the current version of the Zee supports remote plugins, but I may be wrong, I never got a clear answer about that from HST guys
              Anyway, if/when the Zee supports remote plugins, this plugin will be able to connect to it remotely.
                #37
                Great Update! Ill be playing some more this weekend now
                  #38
                  when attempting to install the kinect plug in I get the following error
                  11/10/2013 10:46:00 PM ~!~Error~!~Initializing plug-in(1): Kinect Instance::HSPI::InitIO: Failed to init: Exception: System.IO.FileNotFoundException: Could not load file or assembly 'Microsoft.Kinect, Version=1.7.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35' or one of its dependencies. The system cannot find the file specified.File name: 'Microsoft.Kinect, Version=1.7.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35' at HSPI_KINECT.KinectApp.Init() at HSPI_KINECT.HSPI.InitIO(String comPort)WRN: Assembly binding logging is turned OFF.To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1.Note: There is some performance penalty associated with assembly bind failure logging.To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog].
                  11/10/2013 10:46:05 PM ~!~BLiTunes Error~!~Caught this exception setting up iTunes - Retrieving the COM class factory for component with CLSID {DC0C2640-1415-4644-875C-6F4D769839BA} failed due to the following error: 80040154 Class not registered (Exception from HRESULT: 0x80040154 (REGDB_E_CLASSNOTREG)).
                  need a little help
                  Thanks Ken
                    #39
                    Have you installed the kinect runtime or kinect SDK as explained in the user guide?
                    http://board.homeseer.com/showthread.php?t=162315
                      #40
                      I do. I have been using the Kinect with other applications before. I am running on win 8 64 bit
                        #41
                        do you use Kinect for windows or Kinect for Xbox?
                        what version of the SDK or Runtime have you installed?
                        what kinect application can you successfully run?
                          #42
                          I am using Kinect for xbox and I have used the Kinect with ispy a open source IP camera software. It let's you use the Kinect to setup virtual trip wires to trigger camera functions.
                          Cheers ken
                          Sent from my EVO using Tapatalk
                            #43
                            What version of the SDK or Runtime have you installed?
                            According to the logs the problem is that the plugin cannot find the SDK dlls. So maybe it hasn't been installed correctly or maybe you don't have the correct version. So please try to reinstall from the links in the user guide
                              #44
                              Spud,
                              I was running version 1.6, I see that they have updated to 1.7 so I will download those and give it a try
                              Cheers Ken
                                #45
                                actually the latest SDK released is 1.8, but the plugin has been compiled with 1.7, so you should install 1.7.
                                always use the links from the user guide: http://board.homeseer.com/showthread.php?t=162315
