Multiple Instances
You can control multiple kinect by starting new instances of the plugin. If the kinect is plugged to a remote computer, see the Remote instance section below, if you have multiple kinects plugged into your HS machine, start a new instance of the kinect plugin by clicking the + button from the PLUG-INS > Manage page.
Enter a name for your instance, submit, and then enable it.
This will create a new Config link in the PLUG-INS > Kinect menu, allowing you to choose which sensor this instance is supposed to control and to change the settings for this instance.
Remote Instances
To run the plugin remotely, you need first to install it on your HS machine, even if you don't have a Kinect connected to your HS machine you need to have it installed there (but you don't have to enable it) so that HS doesn't complain about licensing issue when you start your remote instances.
Then
- copy HSPI_KINECT.exe, bin/Kinect/Kinect.Toolbox.dll to a directory on your remote computer
- copy HomeSeerAPI.dll, HSCF.dll and Scheduler.dll from your HS3 directory to the same remote directory
- open a command prompt on your remote computer
- cd to the directory, then type HSPI_KINECT.exe server=<ip_of_your_hs_machine> instance=<instance_name> autoreconnect=<seconds_to_wait> console=<false|true>
where <instance_name> can be anything you want but only alpha numeric characters.
autoreconnect is an optional parameter which makes the plugin automatically reconnect when the connection with HS is lost. It can be useful for example when you want to restart HS without having to restart all the remote plugins manually.
<seconds_to_wait> is the number of seconds to wait before the plugin tries to reconnect.
console is an optional parameter that hides the console window when set to false
