Please use this thread to ask for new features
Kinect Plug-in - Feature Requests
This is a sticky topic.
Plugins: Nest - IFTTT - Kinect - UPB - Kodi - iTunes - Airplay Speak - EnvisaLink DSC / Ademco - DirecTV - Wiimote - Hyperion - Autelis - EasyTrigger - Alexa - Ecobee - Sinope - RaspberryIO - ImperiHome - Chromecast
My blog: http://www.domogeek.ca/blog/
surovich
Im with Automated on that - just like the XBOX sign on ...
Id like to add :
VR parsing so you can ask different varying phrases (Like the built in VR in HS). (ie : Weather for the next |1|2|3|4|5 days) - I need this for one of my custom scripts.
Originally posted by surovich View PostVR parsing so you can ask different varying phrases (Like the built in VR in HS). (ie : Weather for the next |1|2|3|4|5 days) - I need this for one of my custom scripts.Plugins: Nest - IFTTT - Kinect - UPB - Kodi - iTunes - Airplay Speak - EnvisaLink DSC / Ademco - DirecTV - Wiimote - Hyperion - Autelis - EasyTrigger - Alexa - Ecobee - Sinope - RaspberryIO - ImperiHome - Chromecast
so on your example the syntax would be:
Code:Weather for the next <one|two|three|four|five> days
You can add up to 10 multiple choices for the same phrase and get results from the global variables kinectvar0, kinectvar1, ...., kinectvar9Plugins: Nest - IFTTT - Kinect - UPB - Kodi - iTunes - Airplay Speak - EnvisaLink DSC / Ademco - DirecTV - Wiimote - Hyperion - Autelis - EasyTrigger - Alexa - Ecobee - Sinope - RaspberryIO - ImperiHome - Chromecast
Hi Spud, is there a possible to assign a device that show on/off for listening status. If the Attention Phrase is accepted the device status should change to on or similar.Please excuse any spelling and grammatical errors I may make.
Tasker Plugin / Speech Droid
Tonlof | Sweden
Originally posted by tonlof View PostHi Spud, is there a possible to assign a device that show on/off for listening status. If the Attention Phrase is accepted the device status should change to on or similar.
right now, the way it works is that you have to say the attention phrase before each command: "Computer, turn the lights on", "Computer, stop the music", etc..., so the Kinect is kind of always listening.Plugins: Nest - IFTTT - Kinect - UPB - Kodi - iTunes - Airplay Speak - EnvisaLink DSC / Ademco - DirecTV - Wiimote - Hyperion - Autelis - EasyTrigger - Alexa - Ecobee - Sinope - RaspberryIO - ImperiHome - Chromecast
But now I know that I need to say "Computer" before every command whitout any delay.
Thanks for your great work.Please excuse any spelling and grammatical errors I may make.
Tonlof | Sweden
Originally posted by Automated View Post-Recognition of pre-identified/pre-defined persons, so that Homeseer knows WHO is in the room._______________________________________________
HS3 : HSpro (3.0.0.460) on Win2012 (vm on ESXi)
Plugins: HSTouch, UPBSpud, Kinect, Nest, IFTTT, DirecTV, EasyTrigger, Imperihome, Zwave, RFXcom, UltraMon3, UltraWeatherBug3, UltraGCIR3, UltraLog3, UltraPioneer, PHLocation, Pushover, Pushalot, MCSSPrinklers S, JowiHue
Jon00 Plugins: Bluetooth Proximity, Performance Monitor, DB Chart, Links
Multiple Remote Kinects?
I would love to be able to support multiple remote Kinects with this plugin. Ideally I would install a small PC in remote locations to "feed" HS commands. Similar to the Nitrogen device
http://www.nitrogenlogic.com/product...ontroller.html
Thoughts?
Originally posted by footVOL View PostI would love to be able to support multiple remote Kinects with this plugin. Ideally I would install a small PC in remote locations to "feed" HS commands. Similar to the Nitrogen device
Thoughts?
you can already run the plugin as a remote plugin, here is how:
- copy HSPI_KINECT.exe, HSPI_KINECT.exe.config, Kinect.Toolbox.dll to a directory on your remote computer
- copy HomeSeerAPI.dll, HSCF.dll and Scheduler.dll from your HS3 directory to the same remote directory
- open a command prompt on your remote computer
- cd to the directory, then type HSPI_KINECT.exe server=<ip_of_your_hs_machine>
Originally posted by Mad leal View PostVR multiple commands.
I uses homeseer with XBMC and it would be nice for the Kinect to listen for multiple commands for a desired amount of time.
Example:
Like this:
Computer Up - Up - Right - Select
Instead of this:
Computer Up - Computer Up - Computer Right - Computer SelectPlugins: Nest - IFTTT - Kinect - UPB - Kodi - iTunes - Airplay Speak - EnvisaLink DSC / Ademco - DirecTV - Wiimote - Hyperion - Autelis - EasyTrigger - Alexa - Ecobee - Sinope - RaspberryIO - ImperiHome - Chromecast
An easier way to add voice and gesture controls. Maybe have a tab in the plug-in Config where you can configure them.
An empty box were you type the VR phrase and an drop down box were you select what event you would like to run.
BTW The XBMC feature sounds awesome. Thank you all your hard work.
