Originally posted by kideon
View Post
Kinect Plug-in - Feature Requests
This is a sticky topic.
Plugins: Nest - IFTTT - Kinect - UPB - Kodi - iTunes - Airplay Speak - EnvisaLink DSC / Ademco - DirecTV - Wiimote - Hyperion - Autelis - EasyTrigger - Alexa - Ecobee - Sinope - RaspberryIO - ImperiHome - Chromecast
My blog: http://www.domogeek.ca/blog/
Originally posted by kideon View PostIs it possible to have the camera pan left and right? Maybe a repeating sweeping motionPlugins: Nest - IFTTT - Kinect - UPB - Kodi - iTunes - Airplay Speak - EnvisaLink DSC / Ademco - DirecTV - Wiimote - Hyperion - Autelis - EasyTrigger - Alexa - Ecobee - Sinope - RaspberryIO - ImperiHome - Chromecast
Pause/Resume remote instance?
I'm not sure if this has been requested previously. What I would like to do is to be able to have a device in homeseer for each remote kinect instance that would allow me to use an event to pause the remote instance when the room becomes vacant and resume when it becomes occupied. Occupancy/vacancy is handled by other hw/plugins, so this request is just for the ability to pause and resume the remote instance. This is to reduce the cpu utilization when the room is vacant.
In addition the ability to restart the remote instance on failure would be nice. It seems to fail a lot now--which I think you mentioned was an HS3 bug related to restarting plugins on the manage plugins page._______________________________________________
HS3 : HSpro (3.0.0.460) on Win2012 (vm on ESXi)
Plugins: HSTouch, UPBSpud, Kinect, Nest, IFTTT, DirecTV, EasyTrigger, Imperihome, Zwave, RFXcom, UltraMon3, UltraWeatherBug3, UltraGCIR3, UltraLog3, UltraPioneer, PHLocation, Pushover, Pushalot, MCSSPrinklers S, JowiHue
Jon00 Plugins: Bluetooth Proximity, Performance Monitor, DB Chart, Links
Originally posted by jlrichar View PostI'm not sure if this has been requested previously. What I would like to do is to be able to have a device in homeseer for each remote kinect instance that would allow me to use an event to pause the remote instance when the room becomes vacant and resume when it becomes occupied. Occupancy/vacancy is handled by other hw/plugins, so this request is just for the ability to pause and resume the remote instance. This is to reduce the cpu utilization when the room is vacant.
Originally posted by jlrichar View PostIn addition the ability to restart the remote instance on failure would be nice. It seems to fail a lot now--which I think you mentioned was an HS3 bug related to restarting plugins on the manage plugins page.
http://board.homeseer.com/showthread.php?t=162313
Also, Rich has fixed an important problem in HS3 related to remote/multiple instances of plugin in version 3.0.0.219 (not released yet)Plugins: Nest - IFTTT - Kinect - UPB - Kodi - iTunes - Airplay Speak - EnvisaLink DSC / Ademco - DirecTV - Wiimote - Hyperion - Autelis - EasyTrigger - Alexa - Ecobee - Sinope - RaspberryIO - ImperiHome - Chromecast
Any word on when 3.o.o.29 will be released to improve stability of remote instances
Sent from my SM-G928P using TapatalkHSPRO,HS3PRO, BLsecurity, , MCSxap, HSTouch Android, UltraGCIR, CM15a, USBUIRT, BLUSBUIRT, WIFIRGB, BLAB8SS, BLcontrol, BLGData, BLLAN,BLOccupied, BLRadar, BLVolume, iTunesDAAP, UltraGCIR3, Airplayspeak, BLalarm, BLbackup, BLLED, BLrandom, BLReminders, BLRF, BL Speech, Hyperion, IFTTT, KINECT, XBMC, MCSprinkers PRO, PHLocation, ULtrapioneer, Ultralog, ultraweatherbug, Z,troller, GC-100, GC WIFICC, GC-WIFI SERIAL, Nitrogen logic depth camera controllers,
Originally posted by kenrad View PostAny word on when 3.o.o.29 will be released to improve stability of remote instances
it fixes the problem of plugin instances being stopped when another plugin is started/stopped, but use it at your own risk as I don't know what other changes are in there.Plugins: Nest - IFTTT - Kinect - UPB - Kodi - iTunes - Airplay Speak - EnvisaLink DSC / Ademco - DirecTV - Wiimote - Hyperion - Autelis - EasyTrigger - Alexa - Ecobee - Sinope - RaspberryIO - ImperiHome - Chromecast
Instance name in debug strings
Would it be possible to precede each debug/trace string with the instance name?
I had some remote kinect instance disconnect/reconnect issues recently and it would have made it a lot easier to track down if the HS log debug told me which kinect instance was reporting in.
Thanks for a great plugin
Originally posted by JimBob View PostWould it be possible to precede each debug/trace string with the instance name?
Thanks for a great pluginPlugins: Nest - IFTTT - Kinect - UPB - Kodi - iTunes - Airplay Speak - EnvisaLink DSC / Ademco - DirecTV - Wiimote - Hyperion - Autelis - EasyTrigger - Alexa - Ecobee - Sinope - RaspberryIO - ImperiHome - Chromecast
Originally posted by spud View PostI have just posted version 3.0.0.36 in the Beta testing thread
I have also worked on global triggers (i.e. kinect triggers that work for all instances), unfortunately there is a problem in the HS API that prevent this from working, basically a plugin instance cannot fire a trigger that it doesn't own. I have contacted Rich about this but no answer so far.
Thank you for the update on the global triggers. Did you ever receive a response from Rich?
no answer, I just asked againPlugins: Nest - IFTTT - Kinect - UPB - Kodi - iTunes - Airplay Speak - EnvisaLink DSC / Ademco - DirecTV - Wiimote - Hyperion - Autelis - EasyTrigger - Alexa - Ecobee - Sinope - RaspberryIO - ImperiHome - Chromecast
in version 3.0.0.41 available here I have implemented Global triggers (i.e triggers that work for any instance of the Kinect plugin)
there is a new "Global Trigger" option for the "A phrase is recognized" trigger.
For this to work you need to respect the following rules:
- The instance that created the global trigger needs to always run, if it doesn't run the other instances won't be able to fire the event. I would advise to create a dummy instance that is not connected to any Kinect sensor, which runs locally and from which you can configure all your global triggers
- Once your global triggers are configured, you need to restart other instances or run a "Rebuild grammars" action before they are active for other instances. I would advise to create a manually trigger event that rebuild the grammars for each instance, and run it every time you change or add a global trigger.
