Longest USB
I use a 50 foot powered USB extender for my Kinect and modded XBOX 360 and it works fine.. I bought powered USB extender from monoprice
Any other suggestions Spud? Only need it to go about 30' but can't fish USB. Needs to go through cat6 or an RG6U that is already prewired.
worth a try, but I doubt even #1 would work well for kinect
in the description it says
Note: the distance and adapters may affect the performance of some devices down to USB 1.1 speed
Originally posted by 519zwave View PostCat6 convert to USB?
I have 4 CAT6 runs to numerous locations back to Homeseer server room etc.. Can a USB cable be created using the existing CAT6 to run a Kinect?
http://www.amazon.com/HDE-over-Exten.../dp/B004XYEXX4
They just make use of the cat5 wires to extend the USB, so you have to use the cable point to point; not go through an ethernet switch.
And there are these also:
http://www.amazon.com/Digi-AW-USB-2-...gi+anywhereusb
Which is ip-based, so technically you can put the other end anywhere the network reaches (even to another country if you vpn it) or thru a wifi connection, etc.
But I seriously doubt #2 works for Kinect.
Originally posted by Rotech View PostLet me re frase, I have a kinect with its PS. And If I use a extended USB cable, do I need to get another PS for the extended USB cable?
Originally posted by S-F View PostHow are you connecting that cable to the Kinect?
It doesn't have its own power source. I have this one with the optional power supply: http://www.monoprice.com/Product?c_i...seq=1&format=2
Originally posted by eliashall View PostCan you run two Kinects with one USB hub or do they need to be on different hubs?
They are hungry hungry devices so they need to be on different USB ports. Also some motherboards with many USB slots use the same "port" for multiple slots so you will run into issues in those situations too. I think if I decide to run a bunch of them all from my server I'll have to get a good USB card. I don't like the approach of peppering the house with cheap tablets, but it is certainly working for some people.
