Can someone explain to me how this work. I having a hard time trying to understand it. Thank you
Kinect<instance_name>Var<choice_index>
For example if the plugin instance name is "LivingRoom", the global variable for the first choice of your phrase is called KinectLivingRoomVar0
If you want all your plugin instances to use the same global variables (i.e KinectVar0, KinectVar1, ...., KinectVar9) , untick the "Use Global Vars Specifics to Instance" setting in the Voice Recognition tab of the Config page.
