Contacting HomeSeer This Week
See more
See less
kinect stop working suddenly
  • kinect stop working suddenly
    notice yhat the kinect stop working. I restarted PI and got this errorwhat can I do?:
    Jul-11 10:14:50 AM Plug-In Finished initializing plug-in Kinect
    Jul-11 10:14:47 AM Info Plugin Kinect with instance: has disconnected
    Jul-11 10:14:47 AM Error Initializing plug-in(1): Kinect Instance::System.IO.IOException: The process cannot access the file 'C:\Program Files (x86)\HomeSeer HS3\Logs\Kinect.txt' because it is being used by another process. at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath) at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost) at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost) at System.IO.StreamWriter.CreateFile(String path, Boolean append, Boolean checkHost) at System.IO.StreamWriter..ctor(String path, Boolean append, Encoding encoding, Int32 bufferSize, Boolean checkHost) at System.IO.StreamWriter..ctor(String path, Boolean append) at System.IO.File.AppendText(String path) at HSPI_KINECT.Logger.Init() at HSPI_KINECT.KinectApp.Init()
    Jul-11 10:14:47 AM Kinect ERROR System.IO.IOException: The process cannot access the file 'C:\Program Files (x86)\HomeSeer HS3\Logs\Kinect.txt' because it is being used by another process. at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath) at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost) at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost) at System.IO.StreamWriter.CreateFile(String path, Boolean append, Boolean checkHost) at System.IO.StreamWriter..ctor(String path, Boolean append, Encoding encoding, Int32 bufferSize, Boolean checkHost) at System.IO.StreamWriter..ctor(String path, Boolean append) at System.IO.File.AppendText(String path) at HSPI_KINECT.Logger.Init() at HSPI_KINECT.KinectApp.Init()
    Jul-11 10:14:46 AM Info Plugin Kinect has connected. IP:127.0.0.1:63032
    Hector
    Win.2003 OS, HS3
    MyTrigger,ACRF2,W800,Zwave
    AP800,Honeywell Stat
  • #2
    Hey Hector;
    Had a similar problem. Didn't get any error messages, however. I plugged the Kinect back into the XBox and it worked. Concluded that the power adapter that I just bought was bad and ordered another. That did it for me.
    Don
    • #3
      this error means the kinect.txt log file is locked by a program, so if you have it opened in a text editor, close it. Stop the plugin, kill any HSPI_Kinect.exe process from task manager. Then try to start the plugin again.
      • #4
        I had to shut down HS and restart it. Now everything works, wonder what happened here?
        Hector
        Win.2003 OS, HS3
        • #5
          anybody knows what this error means?
          Jul-18 9:49:09 PM Kinect ERROR '' rule reference not defined in this grammar.
          this pops out in start up.
          Hector
          Win.2003 OS, HS3
          • #6
            Bump
            Hector
            Win.2003 OS, HS3
            • #7
              Roughly said.
              Your grammar file does contain a keyword. When hit, this line also contains what to do when this keyword was found. This todo is a reference to another piece in the grammer. That piece isn't found.
              This error is mostly due a typo
              • #8
                Spud, may need to add some extra trapping - you can trip this error if HS is rebooted, and it basically kills the whole plugin remotely without a reconnect.
                Jul-20 02:35:55 DEBUG Speech Recognition Stopped
                Jul-20 02:35:55 DEBUG Snapshot server stopped
                Jul-20 02:35:56 DEBUG System.Net.HttpListenerException (0x80004005): The I/O ope
                ration has been aborted because of either a thread exit or an application reques
                t
                   at System.Net.HttpListener.GetContext()
                   at HSPI_KINECT.SnapshotServer.<Start>b__0()
                • #9
                  This is where I am at now, the kinect isn't working.
                  Hector
                  Win.2003 OS, HS3
                  • #10
                    sorry for the delay, this error means you have one or more voice commands causing a problem when the plugin tries to build the grammar. Could you post your entire debug logs when the plugin starts. Thanks.
                    • #11
                      t
                      Appears this can also be triggered if you restart a plugin from the mange plugins page - for example, restarting zwave will also cause the remote plugin to give the error, and then no longer be active.
                      • #12
                        Here you go spud
                        Hector
                        Win.2003 OS, HS3
                        • #13
                          Here you go spud
                          where do the following rules come from? Why is there some empty optional choices?
                          Jul-20 6:49:28 PM         Kinect    DEBUG Rule (Show Time) [] [] [the] [ days] [] []
                          Jul-20 6:49:28 PM         Kinect    DEBUG Rule: [] [] [the] [ days] [] []
                          also you should avoid entering commands where all words are optional, because that makes the attention phrase with nothing after a valid command
                          • #14
                            Spud, I have no idea why there are empty optional choices. I haven't done any changes on my part.
                            Hector
                            Win.2003 OS, HS3
                            • #15
                              Can you find the events that contains the words in these rules (i.e. "the days") and post them here.
