help newbee
    help newbee
    Hi I'm an old time home seer user. I'm in treated in voice recognition.what do I need to get the X box connect to work.do I need an xbox.sorry for the silly question I'm new to this device
    you don't need the Xbox, you just need the Kinect sensor for Xbox 360.
    Then you need to connect it to a machine running windows 7 on later, on which you would install the kinect drivers as well as the HS3 kinect plugin.
    Read the user guide for more info
      Thanks For ure help that's what I thought. I have one more question maybe u can help. I want to do a new Install hs3.on a raspberry pi2. I have a tablet that runs windows 8.1 so if I can connect the kinect To the tablet do I need to run the speaker server on the pi or on the tablet.also is there a way I can send the commands down to the pi from windows tablet.
      mainly I want raspberry pi to be home seer server I want to install ha touch server on there then I want when motion is sensed to turn on my lights I have Zwave lights want to do this via voice command any thoughts I want to change to embedded solution like a pi
