Log errors
  • Log errors
    Everything seems to be working fine for me apart from getting the following error appear in my log on a semi regular basis.
    Sep-13 11:33:18 Kinect ERROR System.Net.HttpListenerException (0x80004005): The specified network name is no longer available at HSPI_KINECT.SnapshotServer.HandleRequest(HttpListenerContext ctx)
    I do have the snapshot server running and I have got it feeding into BlueIris as one of the camera feeds and that also is working well.
    Any idea what the cause might be given I don't seem to be having problems?
    Alternatively is it possible to provide an option to turn off logging?
    The Kinect camera is running on a remote pc and have made sure the dll files are the same as running on the HS3 pc.
    Kinect 3.0.0.35
    HS3 .199
    I' m not sure what is the cause of this error.
    How often does it happen? Can you reproduce it systematically, for example by trying to access the snapshot server from 2 different program (BlueIris and a browser for example)
    I googled the exception, and most of results say to just ignore it, so in the next version I will probably log it at Debug level only.
      I did a bit more troubleshooting and it seems to only occur when BlueIris is running. That said I can also replicate the issue if I got to the snapshot view in a web browser and hold down the refresh button.
      It varies, from multiple times a second to minutes apart. In the last 24 hours there were 1519 entries. Logging to debug would be most appreciated.
