Voice Recognition Settings Threshold setting changes???
  • Voice Recognition Settings Threshold setting changes???
    I just noticed that when you change the threshold setting in the Voice Recognition Settings tab, it chnage back to the defaulted setting 0.8 is this correct?
    Hector
    Win.2003 OS, HS3
    MyTrigger,ACRF2,W800,Zwave
    AP800,Honeywell Stat
    it works as expected for me
    what browser are you using?
    to what value are you trying to set it to?
    anything in the logs?
      I am using chrome
      I just tweek it up to 1.8
      I get know errors in log.
      I just tried it again, if I set it to 1.8 and leave the page and come back, it changes to the default setting. FYI I am running HS ver .205
      Hector
      Win.2003 OS, HS3
        confidence threshold must be a value between 0 and 1.
          When you click on the value, a box pops up with up and down arrows, I just clicked the up arrow to next level, is that the way of entering values?
          Hector
          Win.2003 OS, HS3
            you should type in the number and submit
            the up and down arrows are added by the browser because I have defined the field as a number, but I'm not sure how I can change the incremental value and if it is consistent across browsers, so in the next version I will define this field as text to remove the arrows
            sorry for the confusion
              Thank you for clarifying spud.
              Hector
              Win.2003 OS, HS3
