Contacting HomeSeer This Week
See more
See less
Kinect needs to be restarted
  • Kinect needs to be restarted
    Current Date/Time: 10/9/2015 7:50:49 AM
    HomeSeer Version: HS3 Standard Edition 3.0.0.208
    Operating System: Microsoft Windows 7 Home Premium - Work Station
    System Uptime: 0 Days 13 Hours 3 Minutes 9 Seconds
    Number of Devices: 211
    Number of Events: 171
    Enabled Plug-Ins
    2.0.22.0: BLDSC
    2.0.14.0: BLOccupied
    2.0.110.0: BLRadar
    1.0.11.0: BLRain8Net
    2.0.5.0: BLRandom
    3.0.12.0: BLReminders
    2.0.63.0: BLStat
    1.0.16.0: BLTED
    2.0.17.0: BLUPS
    3.0.0.75: HSTouch Server
    3.0.0.35: Kinect
    3.0.0.141: PHLocation
    1.0.0.2: Restart
    30.0.0.29: RFXCOM
    3.0.0.38: weatherXML
    3.0.1.25: Z-Wave
    I have been encountering problem with kinect not responding to voice commands lately, To resolve issue I need to restart plugin and that makes it work. Anyone experimenting this?
    Hector
    Win.2003 OS, HS3
    MyTrigger,ACRF2,W800,Zwave
    AP800,Honeywell Stat
    Anyone?
    Hector
    Win.2003 OS, HS3
      This happens to my remote Kinect when there are wifi glitches and the remote computer loses its network connection for a bit.
        Hector,
        Is it a local or remote instance?
        could you provide some logs with log level=trace?
        thanks
          Originally posted by spud View Post
          Hector,
          thanks
          It a local instance.
          When placing log level to "trace" what do you want me to test? Or what do you want me to do afterwards?
          Hector
          Win.2003 OS, HS3
            keep the log level to trace until the problem happens again then post the latest log lines from the Kinect plugin.
              Spud
              today I notice that my TTS event where lagging. I opened task manager and CPU usage was at 100%. I then started turn off processes to see if the CPU usage will scale itself down. the kiect was at around 53k, when I turn kinect process off cpu usage came down to less the 10%. I captured info from log, didnt see any specific error. But maybe you can see things that I dont.
              Hector
              Win.2003 OS, HS3
                Spud
                when you restart the kinect plugin does it immediatly takes 100% CPU?
                the kinect plugin can be pretty CPU intensive especially if you use all the features, try to disable some of them: "Gesture, Posture and Person Recognition", camera, voice recognition...
                  Disabling all except voice recognition is hovers around 32k. If I disable voice reconnition it drops to 25k.
                  Hector
                  Win.2003 OS, HS3
                    Spud, for some reason the log file that I wanted to attach did not work work. but here it is. this was I think not sure before or after I ended the proceeds in task manager.
                    Hector
                    Win.2003 OS, HS3
                      Bump
                      Hector
                      Win.2003 OS, HS3
                        not sure I understand what you mean by 25k or 32k?
                        what you have to look at in task manager is the CPU column, it's a % of the total CPU available (so it doesn't have a "k" at the end)
                        the log you attached only contains the initialization of the plugin so there is not much to see there.
                          The 25k and 32k is the CPU usage, I currently have the plugin disable to see if I get the lagging again. So far it has been stable. Any other test I can do?
                          Hector
                          Win.2003 OS, HS3
                            I am going to try another Kinect device to see if this is a hardware issue. If this doesn't work I may need to uninstall plugin, Any one having issues with this problem?
                            Hector
                            Win.2003 OS, HS3
                              did anyone find a resolution to a local kinect non-response? besides restarting the plug-in? I have this problem and it seems to be getting worse....
