I am using a 360 kinect plugged into a pc in the living room. It seems like it's connected and everything is working, but when I go setup an event, I see the instance in the drop down, but if I select it, it just closes the drop down and doesn't select it. Any ideas what I'm missing?
Event Setup Won't Let Me Select the Kinect Trigger
could you post the debug logs you get when you start the plugin?
did you try to recreate an event from scratch? Sometimes the event page can be a bit difficult to work with.Plugins: Nest - IFTTT - Kinect - UPB - Kodi - iTunes - Airplay Speak - EnvisaLink DSC / Ademco - DirecTV - Wiimote - Hyperion - Autelis - EasyTrigger - Alexa - Ecobee - Sinope - RaspberryIO - ImperiHome - Chromecast
My blog: http://www.domogeek.ca/blog/
Originally posted by spud View Postcould you post the debug logs you get when you start the plugin?
Now it works as it should most of the time. Last night, I had it doing lots of things, but this morning, it wouldn't respond to anything, so I need to do some troubleshooting to see if maybe that pc did something overnight to change it from working or what.
