Error keeps coming up
  • Error keeps coming up
    Kinect ERROR Object reference not set to an instance of an object.
    Tons of this error. I have rebooted and reset everything.
    Not sure what else to do?
    this error is a very generic one, so I would need more context information.
    can you set the log level to debug (or even trace) and post more of your logs?
    when does this error happens? when you start the plugin?
    what version of the plugin are you running? what features are you using? Is it a remote or local instance?
    thanks
      thanks
      All are remote systems. version 3.0.0.40,
      it has stopped for now. so far. but any info on this.
      Mar-18 22:21:00 weatherXML Check timer items
      Mar-18 22:20:58 Kinect DEBUG at System.Runtime.Remoting.Messaging.LogicalCallContext.Propaga teIncomingHeadersToCallContext(IMessage msg) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(Mess ageData& msgData, Int32 type) at HomeSeerAPI.IHSApplication.SetDeviceValueByRef(Int32 dvRef, Double Valuenum, Boolean trigger) at HSPI_KINECT.Zone.set_SkeletonCount(Int32 value) at HSPI_KINECT.VisualRecognition.kinectRuntime_SkeletonFrameRea dy(Object sender, SkeletonFrameReadyEventArgs e)
      Mar-18 22:20:58 Kinect ERROR Object reference not set to an instance of an object.
      Mar-18 22:20:56 Kinect DEBUG at System.Runtime.Remoting.Messaging.LogicalCallContext.Propaga teIncomingHeadersToCallContext(IMessage msg) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(Mess ageData& msgData, Int32 type) at HomeSeerAPI.IHSApplication.SetDeviceValueByRef(Int32 dvRef, Double Valuenum, Boolean trigger) at HSPI_KINECT.Zone.set_SkeletonCount(Int32 value) at HSPI_KINECT.VisualRecognition.kinectRuntime_SkeletonFrameRea dy(Object sender, SkeletonFrameReadyEventArgs e)
      Mar-18 22:20:56 Kinect ERROR Object reference not set to an instance of an object.
      Mar-18 22:20:51 Kinect DEBUG at System.Runtime.Remoting.Messaging.LogicalCallContext.Propaga teIncomingHeadersToCallContext(IMessage msg) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(Mess ageData& msgData, Int32 type) at HomeSeerAPI.IHSApplication.SetDeviceValueByRef(Int32 dvRef, Double Valuenum, Boolean trigger) at HSPI_KINECT.Zone.set_SkeletonCount(Int32 value) at HSPI_KINECT.VisualRecognition.kinectRuntime_SkeletonFrameRea dy(Object sender, SkeletonFrameReadyEventArgs e)
      Mar-18 22:20:51 Kinect ERROR Object reference not set to an instance of an object.
      Mar-18 22:20:37 Kinect DEBUG at System.Runtime.Remoting.Messaging.LogicalCallContext.Propaga teIncomingHeadersToCallContext(IMessage msg) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(Mess ageData& msgData, Int32 type) at HomeSeerAPI.IHSApplication.SetDeviceValueByRef(Int32 dvRef, Double Valuenum, Boolean trigger) at HSPI_KINECT.Zone.set_SkeletonCount(Int32 value) at HSPI_KINECT.VisualRecognition.kinectRuntime_SkeletonFrameRea dy(Object sender, SkeletonFrameReadyEventArgs e)
      Mar-18 22:20:37 Kinect ERROR Object reference not set to an instance of an object.
      Mar-18 22:20:34 Kinect DEBUG at System.Runtime.Remoting.Messaging.LogicalCallContext.Propaga teIncomingHeadersToCallContext(IMessage msg) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(Mess ageData& msgData, Int32 type) at HomeSeerAPI.IHSApplication.SetDeviceValueByRef(Int32 dvRef, Double Valuenum, Boolean trigger) at HSPI_KINECT.Zone.set_SkeletonCount(Int32 value) at HSPI_KINECT.VisualRecognition.kinectRuntime_SkeletonFrameRea dy(Object sender, SkeletonFrameReadyEventArgs e)
      Mar-18 22:20:34 Kinect ERROR Object reference not set to an instance of an object.
