Connect Kinect to what?
    I have read several topics and I just can't seem find an answer to a question that I hope is not just obvious to everyone but me.
    In the Kinect (3P) user guide, it says you can use a Kinect from Xbox 360 - which I have. But what do I connect that to? The plug is proprietary and only fits in the back of an xbox. How do I connect it to a PC?
    Sent from my SM-G935F using Tapatalk
    You can buy a USB adapter. Check on Amazon.
    - Tom
    HSPro/Insteon
    Web Site
    YouTube Channel
      HDE Power Supply AC Cable Adapter for XBox Kinect Motion Sensor
      http://www.amazon.com/Supply-Adapter...+Kinect+Motion
      Jeff Farmer
      HS 3, HSPhone
        Here today use Spud's Alexa and Alexa plug-in with a 17" multi touch (USB) monitor (HDMI) running on a micro PC / Windows 10 computer. Works well.
        Footprint with the Kinect / 17" monitor is a bit larger than the Amazon Echo.
        As mentioned you need a combination power supply and USB cable(s) device.
        Here using the laptop style power supply stuff for my 360's.
        - Pete
        Auto mator
        Homeseer 3 Pro - 3.0.0.548 (Linux) - Ubuntu 18.04/W7e 64 bit Intel Haswell CPU 16Gb- Mono 6.12.X
        HS4 Pro - V4.1.7.0 - Ubuntu 18.04/VB W7e 64 bit Intel Kaby Lake CPU - 32Gb - Mono 6.12.x
        HS4 Lite -
          Pete, Jeff - thank you both.
            The microPC is a PipoX7 which you can just velcro to the back of the monitor.
            - Pete
            Auto mator
            HS4 Lite -
