Only one remote instance shows in menus
  • Only one remote instance shows in menus
    I have two remote instances (no local one) but only one appears in the Plug-ins menu, as "Kinect - <instancename>". This then means that when the kinect instance that does show in the menu is not running, I do not have a Kinect menu option at all, making it difficult to adjust the configuration.
    It used to appear there but mot any more. I have restarted HS but the issue remains. I am on 3.0.0.43.
    Any ideas?
    The menu links with multiple instances of a plugin have always been buggy, but here if I start HS3, then I start a remote instance test1, then I start another remote instance test2, I can see both links in the menu as in the screenshot below. Weird things start to happen if I try to stop one of the instance. I will try to make Rich have a look at it.
      ok, thanks.
