Kinect as PC microphone?
    Hello,
    Can I use a Kinect as a standard PC microphone and make use of HomeSeer's already built in voice recognition features. I'm already making use of that feature mostly via the JSON API and an Android app which captures my voice and sends it as text. I'm also using Jon00's awesome Echo helper script to customize my JSON response text, which is spoken to me. In other words, I don't want to have to recreate my events in order to use a Kinect, but I want a solid, large room, long distance microphone, which I hear the Kinect qualifies as. I'd like to be able to just speak, and not pick up my phone and press a button as I do now. How lazy am I?
    This plugin looks awesome though, however I just want a good mic right now for the built in VR. Can the Kinect do that?
    Thanks!
    HS4, Insteon, Z-wave, USB-UIRT, Google Hub/Chromecasts/Speakers, Foscam & Amcrest cameras, RCA HSDB2a doorbell
    Plugins: BLLAN, BLOccupied, BLUSBUIRT, Chromecast, Harmony Hub, Insteon, Jon00 Homeseer/Echo Skill Helper, Jon00 DB Charting, MediaController, NetCAM, PHLocation2, Pushover 3P, weatherXML, Z-wave
    Yes. Just install the Kinect SDK and you will be all set.
    - Pete
    Auto mator
    Fanless IntelĀ® Celeron N3160 SoC 8Gb
      Awesome! Thank you very much for that information.
      One more question.
      If I buy, say, this one:
      https://www.amazon.com/Microsoft-XBO...ds=kinect&th=1
      Do I need anything else to connect it to a PC? The listing isn't clear and I've read something about needing an adapter or power supply. If I do need something else, any links would be most helpful.
      Thanks!
        Yeah here purchased mine from Gamestop without power supplies. I searched on Ebay and found power supplies for $7.00 each with free shipping.
        Old ad for Kinects on Gamestop shows
        Kinect for Xbox 360 (GameStop Refurbished) Includes:
        Kinect Sensor
        AC Adapter
        USB Cable
        Installation Manual
        You can ask the seller on Amazon what the device includes as accessories.
        - Pete
        Auto mator
          Thanks for the tips. Found one locally at a use games/movies place for $30 with power supply, and a game I'll never use. They'd buy it back for $3 but I just took it.
          Working pretty well as a room mic so far. Not superb, at least yet, with noise in the background. I could perhaps train more.
          Not too pleased with Speaker.exe performance in regards to attention phrase. It activates for all sorts of stuff not even close to the phrase. I've tried multiple two word phrases with poor results. Human conversations and the TV triggered it way too much. Does this plugin do better?
          Question...
          Can I use this Kinect plugin to receive voice commands from the Kinect, and then pass off ANY phrase received to the JSON API...regardless of whether or not I have a specific matching phrase in this plugin? Again, I'm looking to utilize the same mechanisms that the JSON API uses to process request=voicecommand, which appears to be what Alexa uses as well. I already have events and scripts based on that mechanism.
          IOW, can I pass ANY words received to a script, or must they be defined in this plugin in order to do any actions? I think I could write a script to do the rest.
            Originally posted by mrceolla View Post
            Question...
            No you can't. The kinect plugin uses all the voice commands defined in HS to build a grammar in order to do VR. If you don't specify any specific kinect rule, it won't recognize anything.
              Ah yes...a grammar file. Speaker.exe creates one of those. Is there some way I could use Speaker's XML file with this plugin so that this plugin can respond to the voice commands I already have created? I suspect it still wouldn't be able to execute the matching actions without a little help, but if it would at least activate based on my existing phrases I'd be a little closer.
