Activate a ceiling fan based on temperature?
  • randy
    We use the temperature reporting from thermostats to control the fans. The logic for the living room is:
    If the temperature is above x
    And if the fan is off
    And if the house is occupied
    And if the house is awake
    And if the air conditioning is off
    And if there has been Motion in the living room within the hour
    Then turn on the fans
    For the bedroom the logic is the same except it is conditioned by the house sleep mode. If the house is asleep the fan will run.
    We use a virtual device to determine House awake/asleep. The living room fans are turned off when the house is asleep, if the temperature is below x, if there has been no motion for more than 60 minutes, if the AC is turned on or if the house becomes vacant.
  • DR4296
    Well, now I guess I need to find a GOOD Zwave multisensor that will report the temp at regular intervals. Looks like none of the ones on Amazon have a 4 star+ rating.
    But thanks for the switch info!
  • simplextech
    Originally posted by DR4296 View Post
    Do any of you have anything hooked up where a ceiling fan will activate / deactivate at a particular room temperature?
    We recently moved from a house with no ceiling fans to one with two. And our living room has a vaulted ceiling with a very large fan. I use Zwave for light automation. Thought maybe I could give my air conditioner some relief if I brought in that big fan to help.
    Dave
    Yes. I use the temp readings from my thermostat to turn on/off and set speed for my ceiling fan. I use the GE Z-Wave Fan Control that was linked in an earlier post.
  • cowinger
    Dave
    You could use one of these to control the fan.
    https://www.amazon.com/GE-Controls-R...ave+fan+switch
    https://www.amazon.com/Honeywell-Con...ave+fan+switch
    And then use a z-wave multi-sensor which there are too many to list or if you have zigbee then the hue motion sensor (has temp) is a good choice.
    Create an event that turns on the fan when a certain temp is reached and off when it hits another temp.
  • DR4296
    started a topic Activate a ceiling fan based on temperature?
    Dave
