New Pi 3 B+ POE hat
    New Pi 3 B+ POE hat
    I finally received my order of the new POE hat for the Pi 3 B+. It is a very nice little device that only works with the Pi 3 B+.
    It is designed to connect to a 4-pin header on the board. It also covers the GPIO pins, but does not connect through them.
    The device fits very tightly, but I don't understand their thinking on the GPIO pins. It would have been much better if they included the GPIO pins on the top of the board. There is a GPIO socket on the bottom of the POE hat. There are through holes on the POE hat, so a 40-pin header extension can be placed underneath, but this will raise the POE hat about 50% higher. As it is designed they really provided no access to the GPIO header.
    I want to use these for my Z-Nets as soon as I figure out how I will get the Z-Wave daughtercard to connect to the header. I will also have to figure out how to move the Z-Net software to Stretch. I have enlisted some help in that regard.
    I also will be using these as my Hyperion controllers for my holiday lighting. Again the GPIO headers are going to be a problem, but Hyperion only uses 3 of the pins.
    On your 2nd picture, across the top - can you push a header through those holes?
      Yes. As I wrote, "There are through holes on the POE hat, so a 40-pin header extension can be placed underneath". It would make the stack about 1/4" taller and double the gap from the processor to the cooling fan. You could use a stubby 4-pin extension (though a tall would work as there are through holes at this point as well) for the POE header and a long 40-pin extension for the GPIO.
      Click image for larger version  Name:	4-pin.jpg Views:	1 Size:	9.9 KB ID:	1249805
      Click image for larger version  Name:	40-pin.jpg Views:	1 Size:	11.0 KB ID:	1249806
      I have both on order. Here is a shot using some 6-pin header extensions I had on hand.
        Ahh, I see. I was hoping that you could engage a header from the top, but thinking about it, the connector on the hat would be too shallow for that .
          For my Hyperion, I may just solder wires to ground (20), data (23) and clock (19). For the Z-Net GPIO, I will need to use header extensions. It is a shame I cannot find a lower profile header extension. Then the existing connector could be removed from the bottom of the POE hat and it would all fit using the supplied spacers.
          I've checked Newark and Adafruit and haven't seen anything that will work.
          It just doesn't seem like they thought this through, because a GPIO solution could have been built in.
            Update. I received my headers and put together a prototype POE Z-Net replacement. Thanks to help from David (zwolfpack) I have been able to build a Raspbian Stretch version supporting the IP to serial for a GPIO card or USB dongle for Z-Net like function. Since I use DHCP reservations for IP addresses, there is no need for the configuration web pages of the Z-Net. I found a case and some board spacers that should let me package this thing up. I have tested it with the EZZee GPIO Z-Wave controller as well as a USB Smartstick+. Here are some pictures of how it all fits together. I will post pictures when I have it installed in a case. I will be using this case from the Pi Shop.
            Here is the stack of the Pi 3 B+ + POE hat + GPIO card
              Bravo! That looks like a great case for this project.
                Looks slick.
                If you already have the znet you can use a POE adapter for about $10
                https://www.amazon.com/dp/B01MDLUSE7
                  I have a number of those and the TP link version. I also have several Z-Nets using them. They work great. I am just trying to make a nice neat package. There is no rule that says if something is working, it cannot be improved upon
                    Update. I received my headers...
                    Randy,
                    What was the 40 pin header extension you found?
                    -Gene
                      From Adafruit here.
                        Here is the case that I've been using. It should also fit the Rock64 with just a very minor mod. If you needed a hard drive you can fit one in. As far as mounting I just screw the VESA mount on the wall then slide the case on it. They make this in Black, White, Red and Clear. There are places I use the Clear so I can see the LEDs on an Amanation HAT.
                          Just a quick update. There is a problem with the POE hat and USB current to the ports. It is being researched by the Pi foundation and they are close to a cure, but it is not published yet.
                          https://www.raspberrypi.org/forums/v...?f=45&t=220984
                          http://linuxgizmos.com/refund-offere...-power-issues/
                          https://www.theregister.co.uk/2018/0...poe_hat_issue/
                          My first unit using a USB Smartstick+ drops communication every 2-20 minutes. I will have my cases today and will test with the GPIO Z-Wave card. Since this problem only affects USB, they should be fine.
                            I thought I would update this thread. I have all four built, installed and working for a couple of weeks. The Pi foundation sent me 5 more POE hats to replace the originals. They were modified with new filtering for the power supplies and are 100% reliable with a USB device such as a Smartstick+. The originals were fine in every other respect, just problems with USB power.
                            Since I am using the EZZee GPIO Z-Wave boards, I needed to get it all in one package that was too tall for the original Z-Net case. I used the ones in post 6 above. I used a 20-pin header for GPIO and some 6-pin headers (only using 4 pins) I already had on hand for POE. I purchased some 15mm and 10mm brass spacers from Amazon to build the board stacks. I used 4 15mm spacers between the Pi3B+ and the POE hat and a single 10mm between the POE hat and the EZZee GPIO board. The fit was too tight for the GPIO board, so I had to Dremel the end of the board just above the activity LED. Because the board had an etched Z-Wave antenna (I am guessing it is 1/4 wave) where I needed to remove material, I added a short pigtail of the same length as the etched section I removed. I soldered it to the PCB land and trimmed it to length.
                            Click image for larger version  Name:	aIMG_4185.JPG Views:	1 Size:	217.2 KB ID:	1254982
                            Then I built the assembly with spacers, taking just enough off of the 10mm spacer to make the GPIO board level.
                            Click image for larger version  Name:	aIMG_4183.JPG Views:	1 Size:	206.4 KB ID:	1254983
                            Click image for larger version  Name:	aIMG_4186.JPG Views:	1 Size:	106.2 KB ID:	1254984
                            Click image for larger version  Name:	aIMG_4179.JPG Views:	1 Size:	233.5 KB ID:	1254985
                            The case has ventilation holes in the bottom, but the top was solid. I cut a hole directly above the fan for exhaust out of the top. The newest Stretch release from the Pi foundation fully supports fan control on the hat. It works great, varying the speed according to temperature.
                            Click image for larger version  Name:	aIMG_4176.JPG Views:	1 Size:	213.2 KB ID:	1254986
                            Overall, I am very happy with the finished product. I used the same Sandisk and Samsung Micro SD cards, re-imaged with Stretch. Thanks to David (zwolfpack) for help with some details. They have been totally reliable and seem to stay very cool.
                            Click image for larger version  Name:	aIMG_4192.JPG Views:	1 Size:	116.1 KB ID:	1254987
                            Click image for larger version  Name:	aIMG_4193.JPG Views:	1 Size:	187.9 KB ID:	1254988
                            Click image for larger version  Name:	aIMG_4194.JPG Views:	1 Size:	111.8 KB ID:	1254989
                            Click image for larger version  Name:	aIMG_4195.JPG Views:	1 Size:	178.3 KB ID:	1254990
                            Click image for larger version  Name:	aIMG_4197.JPG Views:	1 Size:	207.8 KB ID:	1254991
                            Click image for larger version  Name:	aIMG_4200.JPG Views:	1 Size:	156.9 KB ID:	1254992
                              Hi Randy, here is an article I came across regarding the POE Hat. Not sure you read it, and I'll admit I didn't read your articles yet (duplicate?), but thought I would share this one too.
                              https://www.raspberrypi.org/blog/poe-hat-revision/
