mini-itx board help
    mini-itx board help
    Ok so I have acquired a machine but no power adapter. I am new to the mini-itx world...
    so what do i need to get this puppy fired up?
    the power plug is a small circle style as the power supply must of been external. Cant identify the case but when opening it up .. there is where the round plug that goes to a circuit board then the standard motherboard plugs to the mobo for power. Trying to see how i can determine the power supply needed or if there is a unit i can buy to swap out (cheaply) to use this...
    mobo - https://www.amazon.com/Jetway-NF9E-Q.../dp/B008BWO4E2
    cpu - i3 3220t
    memory - sodimm 4gbx2 (8gb)
    Drives - 120gb ssd / 500gb sata 2.5
    this thing would fit nicely in my entertainment center!!!!
    Pics...
      Going to need any make/model/reference numbers on the small circuit board the power jack goes into or see if you can identify it from somewhere like http://www.mini-box.com/DC-DC - that's whats going to be changing the input power to the standard ATX power socket. I'd hazard a guess at it will be either 12 or 19V 10A or so but that's guessing - there are auto detecting power supplies out there also which will do the hard work for you.
        This is what I used with my mini ITX case
        http://www.short-circuit.com/combo/p...l#.WLRK1mczUeM
        Cheers,
        Bob
          I used an old laptop power supply with a Pico PSU like the ones mrhappy and Blade linked. They work great!
          68 Z-Wave Nodes, 175 Events, 359 Devices
            I'm guessing a 19V supply as well. I have a mini ITX case that has a 19V/6.3A supply. These are similar to those used by a lot of laptops: https://www.amazon.com/s/ref=nb_sb_s...=31FHAXX1CNZHV
            Cheers
            Al
              All my (graveyard) Mini-ITX cases with similar PSU boards ran on 12V rather than 19V. I suggest you try 12V first rather than going direct to 19V.
              Jon
                tried a dell 20w 3.5A.. no dice.. my biggie is that I do not know if it works. dont want to drop a ton on something to just give it a try...
                hmm ill have to think about this..
                  it'll likely be 12v
                  hopefully you did not stuff it up using the laptop psu.
                    finally got around to taking the board out. it is this one..
                    http://www.g-alantic.com.tw/1942/dd-itx90/
                    DD-ITX90
                      DD-ITX90
                      In that case it is Jon00 1 - Me 0, you need a 12V adaptor...one with some current behind it.
