Anyone want to help me set up pfSense?
    #16
    Is MaxMind's DB a DNSBL feed?
    Here's one for folks: following that guide do I have to configure things for OpenVPN as well? And what about firewall rules? Do I need to duplicate my firewall rules for my VPN client or will the regular rules apply?
    Originally posted by rprade
      #17
      No it is a global geoblocking list. PFBlocker blocks network addresses known to be used for malware and similiar.
      IP Geolocation and Online Fraud Prevention | Maxmind
      OpenVPN or any of the optional VPN configurations are similiar that they are all VPN.
      VPN (virtual private network) is an encrypted tunnel from outside of your network to the inside of your network. When you are using a VPN tunnel to access your home network you see everything on your LAN as if you were at home. The firewall rules get autoconfigured for the VPN you are using. No need to change what PFSense configures.
      The VPN tunnel has its own rules on either client or host side. You just configure the VPN settings to match on the Host and the Client. Easy peasy stuff and way easier than a few years ago.
      When the client VPN is up and connected to the host VPN (PFSense) you are protected from the internet via the PFSense firewall. If you open a browser and do a "what is my IP?" you will see your home internet IP address.
      VPN has been around a long time.
      Did this for the airline many years ago.
      It allowed for access from anywhere on the internet. It is a multilayered secure tierd approach using layers like an onion. It is very flexible.
      VPN
      With two PFSense boxes you can create a VPN bridge that is always up between two points of presence; say for remote controlling a second Homeseer 3 box.
      You can do an el cheapo VPN like connection between two points of presence using SSH. In the SSH tunnel you can run other services locally.
      IE:
      1 - SSH to another computer from your desktop to another computer passing port 22
      ssh -D 8888 root@internetipaddress
      2 - configure you favorite local browser to connect to the above via a loopback address / proxy
      general settings - network proxy - manual proxy port 8888 using loopback address of 127.0.0.1
      When you surf you will be surfing from the distantly connected network.
      You can test it by just typing in what is my IP.
      Using SSH you can also configure RDP or VNC within the SSH tunnel as above.
      - Pete
      Auto mator
      HS4 Pro - V4.1.11.0 - Ubuntu 20.01/VB W7e 64 bit Intel Kaby Lake CPU - 32Gb - Mono
      6.10.0.104
      HS4 Lite -
