Using a SATA Hard Drive w/ Windows XP?
  • #16
    You can if you want download a do all Linux Umbuntu repair disk. In it will be GParted which will wipe or reformat the drive with any style format. Another thing if you want is to buy a USB to SATA device ($5 on Amazon) and use MiniTools (free) partition manager to wipe and reformat the drives.
    Tell me what specfic OS you are using (XP Pro) and what hardware you are using and I can probably make up a disk for you and post it to download.
    - Pete
    Auto mator
    HS4 Pro - V4.0.9.0 - Ubuntu 18.04/W7e 64 bit Intel Kaby Lake CPU - 32Gb - Mono 6.8X
    HS4 Lite -
    • #17
      Thanks Pete:
      I am trying to install XP Pro w/ SP3. The hardware is an Atom DS25 with four Gb ram. The controller is an Intel ICH9R. Hard drive is a WD20EARS.
      Very kind of you....
      Don
      • #18
        Don,
        Tried earlier to answer; I am not really good though at typing with the cell phone; even with a keypad for it.....what version of XP Pro do you have? There are two flavors; one corporate (assuming you have that one) and one that you just purchase "off the shelf". I am also assuming you have your serial number to such that you can register it on line.
        What is the mfg and model number of the motherboard? Should be plug n play. The Atom DS25 sounds like a D525 CPU. Shouldn't be an issue. Give me a day or so; will make sure it boots up here before posting it.
        - Pete
        Auto mator
        HS4 Lite -
