TVMC to a smart server?
    Hi, I have a HP smart media server (which currently not using) that was given to me by a friend. It came with software that you add to any other PC so that it can chat within them self to interchange info and backups. Up to this point I am fine.
    I was wondering if it was possible to use this server with TVmc (which I think is the same as xbmc)? I am not no computer guru so bare with me, if this is possible, how do you connect the server to the TV? What ports should my tv have to achieve connecting it?
    Sent from my iPad using Tapatalk HD
    Hector
    Win.2003 OS, HS3
    MyTrigger,ACRF2,W800,Zwave
    AP800,Honeywell Stat
    Kodi (XBMC) and Microsoft Media Center are different applications. XBMC has its roots in XBox media center. That said wiki
    The software was originally produced as a independently developed (homebrew) media player application named Xbox Media Center (abbreviated as XBMC) for the first-generation Xbox game console, and was later made available under the name Kodi (formerly XBMC) as a native application for Android, Linux, BSD, Mac OS X, iOS, and Microsoft Windows based operating systems. It is also available as a standalone version referred to as Kodibuntu.
    To connect to your televison you can utilize an HDMI or DVI to HDMI cable. Audio can be via optical or analog output. (Digital).
    - Pete
    Auto mator
    HS4 Pro - V4.1.11.0 - Ubuntu 20.01/VB W7e 64 bit Intel Kaby Lake CPU - 32Gb - Mono
    6.10.0.104
    HS4 Lite -
      It would appear that tvmc is XBMC (Kodi) with some add-ons preconfigured And it also looks like it's designed for streaming video.
      What exactly do you mean by "connect the server to the tv"?
      Originally posted by rprade
        To stream to it.... Now that Pete mentioned HDMI I need to check if the server has this connection. But if it did, it means I need to have server closer to the TV or get a ext. cable.... Humm
        Hector
        Win.2003 OS, HS3
          Might be easier space wise to utilize the HP Smart Media Server as a NAS for everything and then build a tiny RPi2 ($35) with Kodi.
          What are the CPU / memory specs of the HP Smart Media Server? I would suggest putting the NAS box on the network in a wired network fashion rather than a wireless methodology.
          You can manage the Kodi box with the Microsoft Media remote control. I have read that Kodi works well with the RPi2. Basically all you have to do with the Kodi box is map your media to it. It will catalog all your stuff with icons. Relating to the internet streaming it comes with a bunch of music audio / video streaming stuff.
          TVMC (TVAddons) is kind of a special multimedia plugin for XBMC. Best to read about it.
          Neato thing about Kodi is that you can run it on Android, Windows or Linux (not sure today if it runs on iOS). You can test play with it by downloading the USB stick version of it and boot up your HP Smart Media Server to get an idea about it. Here I run it on KodiBuntu (tiny Linux version of it). The GUI is identical whatever the OS is.
          Here is some Kodi RPi stuff.
          Here is a XBMC step by step for an HP Smart Media Server from 2011.
          [WHS] Getting the Most from XBMC and Windows Home Server Step-by-Step Guide
          - Pete
          Auto mator
          6.10.0.104
          HS4 Lite -
