Well i found out the hard way that the "freezer" trick I read on here actually works.
I even had enough time to get all my files off the HD and make a rescue disk and a image of my HD.
I shut done the HS PC for the electrician to do some work.
When he was done , I went to boot it back up and it was dead.
Question-When I get my new HD, how do i go about installing everything again?
1. I have the rescue disk and disk image of my old HD, so do I just run it?
2. I have a restore disk for this PC, do I run that first and then mount the backed up image?
Tim
ps When you do the freezer trick, as soon as you plug it into the PC, wrap a big bath towel around it.
Tim
