Windows 10 or 7?
  • Windows 10 or 7?
    I moved HS3 over to a Dell laptop where it will live until I figure out a new dedicated box.
    The laptop is running Windows 8 and is full of Dell bloatware.
    I need to do a fresh install and am debating on Win 7 vs. 10.
    It is eligible for the Win 10 upgrade but I want to do a clean install. Hopefully it will let me do this.
    I have an extra Win 7 install and am leaning on this at least for now.
    DSteiNeuro
    DSteiNeuro
    HS3Pro
    MSI Cubi Intel(R) Core(TM) i5-5200U CPU @ 2.20GHz, 2201 Mhz, 2 Core(s), 4 Logical Processor(s) 16GB DDRl RAM
    Enabled Plug-Ins
    BLRussound, BLSpeech, HSTouch Server, JowiHue, MyQ, Nest, Rain8, Squeezebox, Ultra1Wire3, UltraGCIR3, Vista Alarm, X10,Z-Wave
    Although I am not running HS3 on Win10, I hate that the automatic updates are such a pain. I'm sure by now, someone has a hack to remove the automatic updates, but thats one thing to keep in mind about Win10.
    68 Z-Wave Nodes, 174 Events, 326 Devices
      For HS3 installs I would stick with the proven Win7 OS. There are still a few drivers not available for W10 and it really doesn't add any value over Win7 for a HS server.
      -Rupp
        I did love win 7 but have been more than happy with win 10 and glad i did the upgrade (but only if you go with Win 10 pro) as you can turn off the auto upgrades and restarts and the backup features are much better including the keep folder in sync with NAS
          I have been on Win 10 for the last month without any issues.
          There is a registry hack that you can find online now to disable the updates. Very easy and works well.
            I like Win 10
            DSteiNeuro
            Been using it for about 7 weeks. Fast! Low overhead.
            I upgraded from Win 7 Embedded with Chrome.
            Edge is the best browser I have used for HS3. On the HS3 machine any any PC I want to Web control HS3 from.
            There are multiple ways to get around to auto update. Just Google and chose what you are comfortable with
            If you upgrade your Dell from 7 to 10, do the bloated upgrade first. Then create install USB drive and from that drive you should be able to do a clean reinstall.
              Decided to go with Win 7 first. Got rid of all of the bloatware.
              Doing Windows update now, going to take a while.
              I can image and then try Win 10 upgrade later.
              Thanks!
              DSteiNeuro
              HS3Pro
              Enabled Plug-Ins
