Yeah it'll be a PITA to repair it if it is really in bad shape.
Best to keep it powered off until you can see what is wrong with it.
And use a USB to SATA device to check it.
Google drive repair utilities. BUT be very careful using them.
Pete, this is getting more interesting, the PC certainally finds the drive, it shows up in device manager and I can check it with third party prigrammes, just no drive letter.
see attached files.
Just out of curiosity, have you tried assigning a drive letter through the disk manager. My Computer>Manage>Disk Management>right click on the drive>Change Drive Letter and Paths>Add. When you get into disk management it should indicate whether the drive is partitioned and formatted. If it won't let you add a letter, then the formatting has probably been lost.
I have had drive letters removed from functional drives on a couple of occasions over the years without really knowing why.
Yes thought of doing that, however it is not an option in disk management
sigpic A founder member of "The HA Pioneer Group" otherwise known as the "Old farts club!"
Erm when I look at your post the image is there in your quote! I will try and attach it.
This one shows. It is clear that the drive lost its partitioning information. I have no idea how it could have happened. There may be some tools out there to recover the partition data, but if this is an SSD, it is unlikely you could recover it. Was there anything you were doing at the time the partition vanished?
it vanished when I re-installed XP, wonder if I should bite the bit and upgrade to W10 and see if it reapears, very tempted to do just that.
I am thinking that the two 2.5" drives in the little raid cage were identical and each was 120Gb large.
Identically for a image back up or running a raid 1 set up.
I remember doing the XP install with Homeseer 2. I think though you reinstalled XP.
I do not understand though why the second drive is 223Gb?
Looking now at old emails of what I had sent. I did duplicate what I had here with the Foxconn.
PicoPSU, 2 drive 2.5" drive cage, one DVD/CD burner in the front and added one Serial port in the back were the opening was for the regular power supply eh?
Found the emails. You powered it up around May 5, 2012 and asked about leaving the drives in the locked position.
- Pete
Auto mator
HS4 Pro - V4.1.11.0 - Ubuntu 20.01/VB W7e 64 bit Intel Kaby Lake CPU - 32Gb - Mono 6.10.0.104 HS4 Lite -
Pete I change Drive 1 some time ago and it worked perfectly. you remember the spec well.
