Nexus 9 in wall tablet - finished project
  • #16
    Originally posted by ajgyomber View Post
    I personally would use something like this if you have a POE switch:
    https://find-a-poe.com/product/PoE-f...n-PoE-Devices/
    That's a good idea, the ones I looked at were over $100 each. I will be using a Ubiquiti POE switch with my network so those would work well.
    Sent from my SM-G935F using Tapatalk
    • #17
      I used one of these in my house to supplement my non-POE Netgear switch. I have found that POE switches are really loud due to the fans. This thing is dead quiet:
      https://find-a-poe.com/product/WS-GPOE-16-48v120w/
      This is actually how I found this company and that microUSB to POE adapter.
      • #18
        I use one of their other products:
        https://smile.amazon.com/dp/B01IODMB...ing=UTF8&psc=1
        So far so good. I got it because I didn't need a full POE switch and I keep it in one of my Leviton structured media cans. The switch in there is cool enough and narrow enough while giving me trunking and some other advanced features. I don't think I could have gotten that in a POE switch (though they have a POE version of my switch, I was worried about heat mainly in a partially sealed can).
        This gave me the ability to have POE with a very small footprint.
        MeiAutomtion Home
        • #19
          Those look pretty good. I've heard the same thing about the switches being noisy but my media/network/automation will be in a room in the basement so I think the noise won't be a factor. I like the Ubiquiti unified switches due to they can do IEEE 802.3af/802.3at poe+ and passive 24v Poe on any port. That way I'm covered if I used ptz cameras, access points, the devices you mentioned before and everything in between.
          Of course putting everything on one switch maybe a single point failure but I like to be optimistic haha.
          • #20
            Originally posted by jon102034050 View Post
            Funny enough, the back piece of the frame was already constructed, I just simply purchased it from Hobby Lobby. Then, I purchased some scrap barnwood from there as well, mitered the corners, and glued it all together. Nothing is stained at all, its very rough and meant to look distressed.
            If I need to turn on the screen of the nexus manually, I can simply double tap the screen and it turns on (this is built into Android). But, its rare that I need to because I'm using an app called "Motion Detector" that turns on the screen when it detects motion.
            Which Motion Detector program are you using? There is quite a few on Google Play.
            Sent from my Nexus 6P using Tapatalk
            • #21
              Motion detector by emparador
              Sent from my SM-G930V using Tapatalk
              Unconfigured PHP Module
