Joggler Playing
  • #16
    Today playing with a new Realtek Network driver for Windows 8.1 and XP.
    It appears to be working. I had originally modified the XP builds removing the wireless NIC and connecting the USB port to an Asix USB to NIC.
    I do have some 3 XP Jogglers configured for just wireless. Tested the new driver on these and it works.
    Tested the new driver on the Windows 8.1 build and it works there too.
    This now allows for a Gb connection with no hardware network adds using the internally built in Gb connection.
    - Pete
    Auto mator
    HS4 Pro - V4.0.5.0 - Ubuntu 18.04/W7e 64 bit Intel Kaby Lake CPU - 32Gb - Mono 6.8X
    HS4 Lite -
    • #17
      Pete, can one get 8.1 running without an internal HD? I saw a couple references to you running 8 in the seabios thread on Joggler wiki but nothing about HOW you got it running.
      I'd like to replace XP on my last remaining Joggler..
      • #18
        You can give it a try.
        Running 8.1 on a USB stick only lasted a couple of boots and it appeared to mess some with the boot stuff to where it would error out and not boot.
        Here I started from scratch with a zif connected SSD drive installing W8.1 from the installation disk.
        Its been running now for a few weeks just fine.
        Magnus (Moskus) is trying similiar on his physically unmodded but updated with Seabios Joggler.
        What may work better though would be a USB SSD stick. I purchased a few of these to test with relating to OS booting (all of the OS's tested) and they seemed to work way better for me than the regular USB stick. They were being sold by Kingspec. I fit them inside of my Joggler but had to remove the device from the case. I did initially test them with the side USB port. They are much larger than a regular USB stick.
        On another note a new Joggler / Openframe EFI test.
        One of the Joggler users noticed that the PATA boot driver was included in the boot EFI bios on the Openpeak 7e.
        I have taken this bios saved from the Openpeak 7e and installed it on an Openpeak 1.0 device and its working.
        Last week I did remove the "test" touch screen interface plugin for Windows 8.1 with some bells and whistles and reinstalled the stock included touchscreen generic drivers. They work fine with HSTouch.
        - Pete
        Auto mator
        HS4 Lite -
        • #19
          11th of July, 2014
          Some more Joggler playing.
          Really though Openframe 2 playing.
          Soldering a PATA port and Micro SD slot to the motherboard in the next few days.
          Looking to "socket" the flash rom chip.
          - Pete
          Auto mator
          HS4 Lite -
          • #20
            You really need a zipper on that thing. :-)
            Don
            • #21
              Yup; from what I can tell there is a different ROM bios in the Telio Openpeak devices. This causes some weird issues in the MMC boot EFI partition. I have not seen any problems with the plain jane Openpeak, Ayaya, Cisco or Verizon boot roms. The more I play with the device the more I learn about its nuances. IE: by default it loads the sound drivers for the DECT phones; but not the DECT stuff.
              - Pete
              Auto mator
              HS4 Lite -
              • #22
                Playing today with a prototype and I have no idea what is different about it yet; it just isn't the same; if that makes any sense.
                - Pete
                Auto mator
                HS4 Lite -
                Unconfigured PHP Module
