Yoga Tablet 2 8
  • Yoga Tablet 2 8
    Thought maybe worth posting that these things work great with HS Touch for Android. I've got four so far and will probably pick up a couple more while they're still ~$150.
    The YT3 has a lower screen resolution and no improvement on CPU or memory that I can see.
    They stand up on their own nicely, work at multiple angles, can even be hung from a nail on a wall if that's your thing. Power off a pretty low-power USB just fine. Screen is pretty dark at night; so can be used on a night-stand reasonably well (not perfectly dark, of course).
    Running HS Touch 3 with them on 24/7. Very responsive and attractive controllers. Hard to believe they're $150.
    I saw these at best buy a while back and thought they would also be good under a cabinet... if HSTouch would rotate properly to the other landscape direction.
    I might still grab one for next to the bed, my current screen i think is too bright even when all black and screen dimmed way low.
      Rotates perfectly here.
        You can do all 4 axis? All my android tablets only allow 2 axis. I didn't think they updated the android client to fix that.
          I'm only using landscape - both versions. I can't see why portrait wouldn't work, unless you mean in one HST load?
          I'm not sure how I'd go about building an HS Touch interface that would do rotation? I don't think I'd want to, but I'd try it for you if you think it should work... or just send me yours.
            So you're saying that if you turn the device upside down the HSTouch project isn't upside down also? I have never seen that.
            Originally posted by rprade
              Yea that is what I am curious about. This tablet I think would be good mounted under a cabinet but concerned that the project would be upside down. Currently this frustrates me with my other tablets because the wire is in the wrong spot
                Just flips right upside down as I'd expect it to. Sloppy and crappy as the UI may be... here it is sitting in front my my junk-tray and hanging off the top of my monitor. Nothing to change. Just flip it over.
                Audio on it is quite good, BTW: speaks perfectly from all the tablets just as expected and plenty loud enough to hear.
                I keep them in the "screen stays on with power" mode. I haven't played with the nightstand one yet; so not sure how I'll do the power / display on that one. They seem to go plenty dark in other rooms; but dark enough as a bedside clock is another matter.
                  On special for $139.99 ship free.
                  Use coupon "USPYT832310" on the Lenovo Website when you check out... It will show a different price with a different discount, but add it to you cart and then use the coupon, it will remove the current special price and updated it to 139.99.
                  My home is smarter than your honor roll student.
                    Where?
                      On the Lenovo Website.
                      Unconfigured PHP Module
