WinkRelay
    WinkRelay
    I managed to get HS running on a WinkRelay.
    I wish I knew this was possible a few months ago. They had one on clearance at my local home depot for cheap.
    Sent from my XT1585 using Tapatalk
    MeiAutomtion Home
      I have a wink relay at home, can you explain how you did it?
      thanks
        How It is done
        I am not taking credit for as I found it on the web....
        Here is what I did.
        Hold top switch and press reset button on bottom. Hold top switch until recovery screen is displayed. Choose last option to restore to factory.
        After restore, when relay boots up and is at login screen, cover sensor at top and hold down bottom switch until relay clicks multiple times. Release bottom switch and you should be at Android home screen.
        Open settings, navigate to security, check unknown sources. Repeat step 2 to get back to home screen
        Open browser, navigate to apkpure website and download
        Chrome (choose version compatible with Android 4.3)
        assistive touch for android 2
        Nova launcher so that you can set it as your default home app
        Make sure Nova is set as your default home app
        Open assistive touch and set it up. I added some favorites for easy access.
        Open Wink Relay app, login and update software to latest
        After reboot, use assistive touch to go back to home screen
        Open Chrome, Google "KingRoot" and download KingRoot from XDA.
        Run KingRoot and you should get message that your device is rooted.
        Open Chrome, go to apkpure website and search for "full!screen" and download it. Open and install it and set it up to run at startup. I personally set the virtual buttons in the corners to completely clear so you can't see them, but they're there. Also made them small.
        (Optional) Search apkpure for "BuildProp Editor" and download and install. Open app and scroll down to "qemu.hw.mainkeys" and change the value to 0. This will enable the bottom navigation buttons.
        Just search APKPURE for HomeSeer and this it...
        Jay
          Wow, thank you
            They are selling for $69 at HomeDepot. How well does HS Touch run on the Wink Relay? How is the touch screen response?
            Ultrajones
              Following along, very interested to hear how well the relay runs homeseer? this would be great in a few locations around the house and the cost would be hard to beat for a mini wall mounted screen.
                any reason why you couldn't get imperihome to run on this as well?
                  That's exactly what I am thinking...
                    I just did it. thanks for the instructions. Used most of it, now have imperihome running. The biggest pain is not having access to play store, so I can't download purchased apps.
                      Are you unable to get Imperihome Pro on it due to this?
                        Actually I did it, I basically backed up my owned version, took the apk and downloaded it onto the relay and installed it
                          Need pic 😀
                            You all still like this.....? They are on Amazon. https://www.amazon.com/dp/B00MU6GLT6?psc=1
                            Sent from my GT-N5110 using Tapatalk
                              Can you control the switches?
                              Is it possible at all to control the two switches in the relay from HS? Are they addressable devices of some sort?
