Ap800 error
    Ap800 error
    I wanted to know if anybody seen this problem before, I am trying to change some setting in the apware (the world is spining) but when I try changing any setting the log error pops out a gives me these error:
    10:24:06 PM (Error -16) There is no DSR signal. Check cabling and make sure you have a device at the other end.
    10:24:09 PM (Error -1) No Response from AP Units.
    10:24:09 PM (AP-Ware) Disconnecting from the site.
    I checked cables and ports everything seems ok. Is it possible to check any setting on the ap800 to see what may have accepted?
    Hector
    Win.2003 OS, HS3
    MyTrigger,ACRF2,W800,Zwave
    AP800,Honeywell Stat
    If your not using VISTA, it might be a problem with your unit, because I have never seen that one before. With Vista, its probably a Vista problem because APWare was designed back in the days of Windows 3.1 XP generally works, but sometimes you need to connect a few times for it to work.
