After doing this for 7 years or so, I'm finally - for the first time - going to try and add VR to my set-up. I've read through a ton of the threads here, and I've purchased a single PZM11LL that I plan to either run directly into the line-input of my sound card, or through a RLY8 relay if I get convinced I need to turn it on and off to avoid false triggers.
With a single mic, I'm wanting to place it in our great room where the entire family spends most of it's time. After looking at the layout of the kitchen, family room, and breakfast nook (components of the great room), I've found the wall I think would be the best place to mount it. However (here's the stupid question), it would be right under the left speaker of the whole house audio. I.e., when I start "conversing" with HS, is this going to cause a problem or some sort of feedback?
My instinct is that this is a very bad idea, but I figure it has to come up with others doing this, even though I couldn't find any thread on it. It seems like the same reasoning you would use for where you want to put the speakers is pretty close to the reasoning of where you would put the Mic. Am I crazy?
Steve
Steve
