Ok gang,
I need some creative help here. I think I have got to compliacated for my own good!
Here is what I currently have and what I am trying to achieve as the end goal.
Software:
MainLobby with the Russound CAV6.6 PLugin and the HomeSeer plugin
HomeSeer 2.2
J River Media Center
Hardware: (Home Automation Computer)
Each channel of the SoundBlasters map to a source on the Russound
SoundBlaster X-FI #1
SoundBlaster #1 Front Channel maps to Russound CAV6.6 Source 1
SoundBlaster #1 Center Channel maps to Russound CAV6.6 Source 2
SoundBlaster #1 Rear Channel maps to Russound CAV6.6 Source 3
SoundBlaster X-FI #2
SoundBlaster #2 Front Channel maps to Russound CAV6.6 Source 4
SoundBlaster #2 Center Channel maps to Russound CAV6.6 Source 5
SoundBlaster #2 Rear Channel (Not used)
Russound XM Tuner maps to Russound CAV6.6 Source 6
JDS Stargate used to turn relay on/off connected to Russound Page to more precisely control Russound Page
Gentner AP800 (Voice Recognition)
8 Mics Around the house tied into the Gentner
Text to Speech from Home Automation Computer tied into Gentner AP800
Mic in to Home Automation Computer from Genter AP800
So, with this setup, I am able to listen to 5 different music sources coming from the J.River Media Center. I am also able to play XM on source 6 on the Russound as well. When a phone call comes in, I am able to interrupt all six Russound sources by using the Stargate to enable the relay to the Russound Page output. The text to speech output from the Home Automation computer announces the caller (the text to speech from the home automation computer is tied into the Gentner AP800). I have Westminster chimes also interrupting every hour playing the chimes. All of this works well.
Now here is what I am now trying to add to the system. I am just now getting the voice recognition working using open air mics and the Gentner AP800 to work in my system. What I would like to be able to do is when a user speaks a voice recognition command in a room, I would like for the Text to Speech ouput to ONLY output to that room. Using the page feature of the Russound, all rooms will get the text to speech output, so that will not work. The only thing I can think of is getting rid of source 5 from the J-River and use that as an output from the Gentner AP800 and then issue commands to the CAV6.6 to tie source 5 of the Russound to the Gentner.
I know I am probably making this more complicated than it needs to be.
If I have to add more hardware, I am ok with that too. Just not sure what I need to add to make this all work.
Any advice would be greatly appreciated.
Thanks!
Chuck
Software:
HomeSeer 2.2
Thanks!
Chuck
