FitbitSeer, a Fitbit plugin for HS3 - Need beta testers
    The default time is every 5 minutes, not 2 hours. I think I told you to set that time earlier...
    But that won't do anything, except give you a new stair count error every 5 minutes instead of every 2 hours.
      OK, I bit the bullet, removed the plugin, devices, files, removed permission from fitbit for plugin, then re-installed, re-authenticated.
      So I have my nice new shiny devices getting updated again. Fingers crossed it behaves.
      Thanks for your help.
        I'll help!
          I'm hoping, since you haven't said anything, that it now works...?
            I haven't had any issue with mine. (if that helps)
            HomeSeer Version: HS3 Pro Edition
            Operating System: Microsoft Windows 10 Pro
            Processor Type and Speed: i7 - 3.26 GHz
            Total Physical Memory: 16Gig
            Plugins: BlBackup | EasyTrigger | FitbitSeer | HSTouchServer | Insteon | WeatherXML
              Yep, still updating. I think I'll put it down to a HS3 "wobble"
                This just happened to my wife's account! I only had to re-authenticate and it was up and running.
                I have no idea why it happened, and I can't see anything in the log either. Very strange!
                  Weird, eh.
                  How do you re-authenticate without re-installing the plugin? May need to know if it happens again.
                    click on the device name for: Refresh now, then when the properties open, choose the fitbitseer tab. You can do it from there.
                      Ahh ok, thanks. I should have tried that myself when I had the issue
                        Yeah, my bad.
                        I should have told you, I really don't know why I didn't.
                          No problem. I have been enlightened now anyway
                            I got a Fitbit as a present. I already have a non-fitbit scale. Is it possible to send this weight to the fitbit api? So I can use the data in the app?
                              I don't really know, but I don't think so. I believe input to the Fitbit database is Fitbit devices only!
                                You can enter weight directly into the app. Go to the dashboard and then manually record your weight as required
