FitbitSeer, a Fitbit plugin for HS3 - Need beta testers
    This plugin looks great! Is there a trigger or condition for when someone is asleep? I see that there is a start time but is there a device to show asleep / awake?
    Thank you!
    Plugin's:
      Hi'
      i am not at home right now. is your plugin linux compatible?
        Originally posted by MattLau View Post
        Hi'
        I think so, but I haven't testet it myself recently.
          I was going to ask you the same question again lol.
          I did not bought any Fitbit so I can't test it yet, but the plugin is loading in Linux, and i am able to access the config page.
          Will maybe try the charge 3 soon.
            Hi Moskus,
            Not sure if this is a Linux bug, but each time the plugins polls data, it creates new devices.
              Tried to remove all the files in hs directory. Reinstalled the plugin again. But got the same issue.
              edit: it creates new devices for every node*
                Juste tried both version on the plugin. It show to same behavior.
                It now have ionic data.
                is there comething a could do on my side? Moskus
                  Hi Moskus,
                  I have never ever seen this behaviour before. What version of HS3 are you using and on what plattform (Windows, Linux)?
                  Do you have mulitple root devices as well? Are they hidden? There is something off with the sorting... Try turning on "Show devices in groups" using the purple icon in the top right corner of the interface.
                    I Moskus,
                    I am on Linux.
                    after reading on the dev forum about the time It tke to update the fitbit database on the web .. I did sent back my Fitbit devices so the store.
                    So I wont be able to help on this onez
                    sorry,
                    Matt
                      Yes, the connection is not in real time.
                      However, if anybody else is wondering. The solution is to delete all Fitbit devices in HomeSeer, and re-add your account.
                        I tried the plugin on my HS system but no joy -- even though I get to the authentication page with the checkboxes and create a root device, the refresh button does nothing and no child devices are created. Also FitBitSeer does not show as an authorized app on my FitBit account. I did check for the Newtonsoft.Json.dll and none is present on my system. I did not find any log files either. I removed the plugin for the moment but I would like to try again if you can give me some diagnostic pointers.
                        Current Date/Time: 1/5/2019 2:08:39 AM
                        HomeSeer Version: HS3 Pro Edition 3.0.0.478
                        Linux version: Linux grendel 4.15.0-43-generic #46-Ubuntu SMP Thu Dec 6 14:45:28 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux System Uptime: 0 Days 5 Hours 41 Minutes 45 Seconds
                        IP Address: 192.168.1.11
                        Number of Devices: 711
                        Number of Events: 5
                        Available Threads: 192
                        HSTouch Enabled: True
                        Event Threads: 0
                        Event Trigger Eval Queue: 0
                        Device Exec Queue: 0
                        HSTouch Event Queue: 0
                        Email Send Queue: 0
                        Anti Virus Installed:
                        Enabled Plug-Ins
                        2.0.29.0: BLRing
                        3.0.0.31: EnvisaLinkAdemco
                        3.0.0.12: EVCStat
                        3.0.1.8: ISYInsteon
                        3.4.17.1: mcsMQTT
                        3.1.0.6: MeiHarmonyHub
                        1.2018.717.1011: MyQ
                        3.0.0.14: NetCAM
                        1.0.0.1: RainMachine
                        3.0.0.37: Vista Alarm
                        3.0.0.88: weatherXML
                          Looks like my authentication problems are related to the version of Mono that was on my system, I've updated to 5.18.0.225 and now can authentication successfully but whenever I hit refresh I get the devices duplicated. Also getting errors retrieving heart rate.
                          Current Date/Time: 1/6/2019 7:29:16 PM
                          Linux version: Linux grendel 4.15.0-43-generic #46-Ubuntu SMP Thu Dec 6 14:45:28 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux System Uptime: 0 Days 0 Hours 27 Minutes 16 Seconds
                          Number of Devices: 708
                          Number of Events: 7
                          Available Threads: 199
                          Event Threads: 0
                          Email Send Queue: 0
                          Enabled Plug-Ins
                          2.0.29.0: BLRing
                          3.0.0.12: EVCStat
                          0.2.0.10: FitbitSeer
                          3.0.1.8: ISYInsteon
                          1.2.1.12: Life360
                          3.4.17.2: mcsMQTT
                          3.0.0.14: NetCAM
                          Jan-06 7:30:11 PM FitbitSeer Debug Could not get heart rate
                          Jan-06 7:30:08 PM FitbitSeer Debug Could not get heart rate
                            Yes, this started happening some time after .435 of HomeSeer and I have no idea what's causing it.
                            There is a way to solve it, though. Delete the root devices and child devices, restart HomeSeer and authorize again.
                            I don't know why that works, but it does...
                              That seems to have fixed it. I had tried deleting devices before but did not restart homeseer I think. Does the problem ever spontaneously reappear?
                                I am seeing a debug notice that FitBitSeer cannot retrieve the heart rate -- unfortunately it does not indicate which user it is trying to retrieve it for -- my fitbit has a heart rate monitor but my wife's does not.
                                an-07 10:00:08 PM FitbitSeer Debug Could not get heart rate
