Contacting HomeSeer This Week
See more
See less
FitbitSeer, a Fitbit plugin for HS3 - Need beta testers
  • As you can see , the sleep end is almost instant!
    but a big delay for the sleep start ; i can live with that since i just want to activate a scene ( witch deactivates a couple of things here)when i am sleeping: e.g disable events that are turning bedroom lights on when a sensors detect motion near the door motion/ same thing for tts...etc ).
    the metric : time asleep is a little odd.
    • Sleep data (Sleep Start, Sleep End, etc) won't update until there are some sleep data to report. This means that the "Sleep Start" usually won't be updated until after you got out of bed...
      • Plugin keeps failing.
        I've been having this issue for a number of months. The plugin disconnects and then just stops responding. if I go in and disable/re-enable, it will run for a few hours and then stop running again. The debug logs didn't show anything.
        I had a similar issue with another plugin. The problem was found to be an issue with the way the PI was interacting with it's devices on systems with high devices counts (5k+).
        Logs are below.
        It fails right after attempting an update.
        CPU on the system never goes above runs around 20%-25% and rarely spikes of 30%.
        Sep-02 12:01:45 PM Warning Plugin FitbitSeer is not responding but it is still running, not restarting yet.
        Sep-02 12:01:21 PM Warning Plugin FitbitSeer is not responding but it is still running, not restarting yet.
        Sep-02 12:01:02 PM Info Plugin FitbitSeer with instance: has disconnected
        Sep-02 12:00:00 PM FitbitSeer Timer elapsed. Updating Fitbit-data.
        Sep-02 11:45:00 AM FitbitSeer Timer elapsed. Updating Fitbit-data.
        Sep-02 11:30:00 AM FitbitSeer Timer elapsed. Updating Fitbit-data.
        Sep-02 11:15:00 AM FitbitSeer Timer elapsed. Updating Fitbit-data.
        Sep-02 11:00:00 AM FitbitSeer Timer elapsed. Updating Fitbit-data.
        Sep-02 10:45:00 AM FitbitSeer Timer elapsed. Updating Fitbit-data.
        Sep-02 10:30:00 AM FitbitSeer Timer elapsed. Updating Fitbit-data.
        Sep-02 10:15:00 AM FitbitSeer Timer elapsed. Updating Fitbit-data.
        Sep-02 10:00:00 AM FitbitSeer Timer elapsed. Updating Fitbit-data.
        Sep-02 9:45:00 AM FitbitSeer Timer elapsed. Updating Fitbit-data.
        Sep-02 9:35:13 AM Starting Plug-In Plugin FitbitSeer started successfully in 26258 milliseconds
        Sep-02 9:34:47 AM Starting Plug-In Initializing plugin FitbitSeer ...
        Sep-02 9:34:47 AM Info Plugin FitbitSeer has connected. IP:127.0.0.1:57251
        Any Thoughts????
        My home is smarter than your honor roll student.
        • Originally posted by Mr_Resistor View Post
          Any Thoughts????
          I can take a look, but this plugin runs fine on other systems with a high device count, so I'm not sure.
          • Thanks for the Plugin. I got a Fitbit Versa 2, mostly so I can give HomeSeer Alexia voice commands from my wrist. So far the Versa 2 is working great and Alexa is responsive using the Jon00 Alexia plugin.
            The Fitbit plugin was a pretty easy install and so far is also working great. The fitness information is really useful and maybe I can get my sleep to improve
            DSteiNeuro
            HS3Pro
            MSI Cubi Intel(R) Core(TM) i5-5200U CPU @ 2.20GHz, 2201 Mhz, 2 Core(s), 4 Logical Processor(s) 16GB DDRl RAM
            Enabled Plug-Ins
            BLRussound, BLSpeech, HSTouch Server, JowiHue, MyQ, Nest, Rain8, Squeezebox, Ultra1Wire3, UltraGCIR3, Vista Alarm, X10,Z-Wave
            • Originally posted by DSteiNeuro View Post
              You're welcome!
              OOoh, jealous of the Versa 2, I would love to have Alexa on my wrist.
                ... I got a Fitbit Versa 2, mostly so I can give HomeSeer Alexia voice commands from my wrist. ...
                Wait, WHAT?!? You can do that? My 12th Fitbit recently died and I am debating getting another or an Apple Watch. How does the Versa communicate with Alexa? Is it BT through a phone to the Alexa app?
                • How do you talk to Alexa on your wrist and keep her from listening on the other devices that are near when at home? I'd have to whisper
                  -Rupp
                  • Originally posted by Rupp View Post
                    A first world problem right there...
                    • Norton was preventing the "suspicious program" from running, and the notification was hidden under the Homeseer Speaker. Once I figured that out and told Norton to behave itself, the install ran like clockwork. Now to figure out how much nagging I'll allow the HS/Fitbit combination.
                      Thank you!
                      My system is described in my profile.
                      • Originally posted by JLehnert View Post
                        Thank you!
                        Great!
                        Thanks for info om the false positive, I can't explain that.
                        • Hi,
                          Just installed the plugin and so far it looks great! Many thanks for creating it!
                          One thing, I can't see my Device Battery Level.
                          I have a Versa 2, is that unit supported?
                          thanks in advance
                          Mats
                          • Originally posted by Mats2 View Post
                            Hi,
                            The unit is supported (my wife has it), but showing battery level is not. It's not present in the Fitbit API.
                            • Just noticed the plugin hasn't been updating since the middle of January. IIRC Fitbit pushed a software update around then and am wondering if that's the issue. Anyone else have the same problem? I'll go through the connection process again over the weekend and see if that fixes things.
                                It works just fine here.
                                My guess is that you just need to re-authenticate. You can do that from the root device of the account devices.
