FitbitSeer, a Fitbit plugin for HS3 - Need beta testers
    That sort of takes away the automation in Home Automation
    Maybe this can help to clarify. There is a way to use the API to log weight. It's described here.
      I had misread the question. [emoji1303]
        Well it quit working. Nothing new added just stopped updating.
        I re-authenticated and still nothing. No debug logs to really tell me what's wrong either.
        This is something that I use every day so I am very sad. There was some talk of changes that were going to be made yet it looks like dev is dead. I sure hope that's not true.
        Tony
        HomeSeer Version: HS3 Pro Edition
        Operating System: Microsoft Windows 10 Pro
        Processor Type and Speed: i7 - 3.26 GHz
        Total Physical Memory: 16Gig
        Plugins: BlBackup | EasyTrigger | FitbitSeer | HSTouchServer | Insteon | WeatherXML
          Same here...
          If you have re-authenticated and it still does not work, then I'm not sure what's wrong. Any authentication error should show in the log.
          You re-authenticate, press "Update now" and nothing happens?
          Well, yes. I'm still waiting to get one of the newer Fitbit devices that support heart rate, but I don't go around buying fitbit devices for the sake of it.
          And I found that debugging data that aren't there is a pain (things have been happening behind the scene, but there's been more problems than solutions so far... ).
          Fitbit does not have a "sample user" with all kinds of data, and that makes this harder than it should be.
            Hi Moskus, I've had to re-authenticate a few times in the past but this time it just wont work. When you he update now it only updates the master device.
            Thank you!
              I've sent a request to Fitbit themselves. They aren't usually fast to reply...
              But I've seen that they've made some changes, and others have had some problems too, but not any more apparently.
              Have you tried again today?
              I'm afraid that's all I can do at the moment.
                I'll give it a try. I realize you are doing the best you can.
                Thank you,
                Tony
                  Still nothing?
                  The last time this happened, the error apparently fixed itself. At least, Fitbit did not tell me what they did.
                    Yes... Just tried it today and it worked! (at first I thought it didnt) YAY!!!!
                      Well, that's good news.
                      But it bothers me that I can't figure out what's going on!
                        just installed and viola.. no issues..
                        so no previous days.. just current at check in?
                          should test drive a new one from bestbuy or something with heartrate monitoring... and bet you wont like is so return it within the return policy and we get HR added!!!!!
                            Yeah... except I'm in Norway...
                              lol i noticed that after i posted it but was too tired to fix.. LOL...
                              so in Norway... is it BeastBuyers ?
                              still thx this is awesome as it was a quick follow steps and BAMB worked without a hiccup
                                I think I can justify the cost if I give it to my wife... She is jogging more than me (my joints like it better when I swim).
