Hmmm! I have a hard time wrapping my head around this. It's hard to debug when I can't replicate an error.
I might have to release a new update with more debug logging so that we can trace it.
To stop the plugin, it's easiest to disable the plugin, and then kill the process HSPI_FitbitSeer.exe (e.g. using Task Manager). Then re-enable the plugin.
Can you reach www.fitbit.com from the HS3 server?
FitbitSeer, a Fitbit plugin for HS3 - Need beta testers
I'm also seeing the plug in crash once an hour with matching application errors in the Windows event viewer. Running Windows 8.1, HomeSeer 3.0.0.208, FitbitSeer 0.1.0.1.
-Chris
If debug is enabled for plugins you can have a hanging window that can look like that.
Have you checked that the plugin process is dead when HS i shut down?
Regards
Morten
mmm, thanks for that. I'm a bit reluctant now to restart HS or I could lose the plugin altogether like you.
I was getting the same error as you once an hour for the last few days as well. Yesterday I did a full reboot because of Windows updates and it started with the above messages. Disabled the plug-in last night when it was flooding the log. I'll jump on and re-enable it and see what happens.
Chris
Originally posted by JimBob View PostAre your errors every hour also?
Oct-19 9:21:46 AM Warning File does not exist: C:\Program Files (x86)\HomeSeer HS3\html\
Oct-19 9:04:47 AM Warning I/O interface FitbitSeer is down, executable is not running, restarting ...
Oct-19 8:04:42 AM Warning I/O interface FitbitSeer is down, executable is not running, restarting ...
Oct-19 7:04:37 AM Warning I/O interface FitbitSeer is down, executable is not running, restarting ...
Oct-19 6:04:33 AM Warning I/O interface FitbitSeer is down, executable is not running, restarting ...
not sure about the 9:21am error..im still getting things going...
I have been running the fitbit plugin since 29th September so a couple of weeks before this error started.
The only change I can think of is that I bought a second tracker and installed a second dongle into another PC (not running HS) but this was a week before the errors started.
Checking back through my windows event log, I can see that I am getting this plugin crash on the hour (within a few minutes) every hour since 14th October 19:00 BST.
There are 2 errors for each crash in the windows application log:
1)
Application: HSPI_FitbitSeer.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.NullReferenceException
Stack:
at HSPI_FitbitSeer.FitbitSetup.UpdateData(Int32)
at HSPI_FitbitSeer.CurrentPlugin._Lambda$__4(System.Object)
at System.Threading.ThreadHelper.ThreadStart_Context(System.Obj ect)
at System.Threading.ExecutionContext.RunInternal(System.Threadi ng.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
at System.Threading.ExecutionContext.Run(System.Threading.Execu tionContext, System.Threading.ContextCallback, System.Object, Boolean)
at System.Threading.ExecutionContext.Run(System.Threading.Execu tionContext, System.Threading.ContextCallback, System.Object)
at System.Threading.ThreadHelper.ThreadStart(System.Object)
2)
Faulting application name: HSPI_FitbitSeer.exe, version: 0.1.0.1, time stamp: 0x55846175
Faulting module name: unknown, version: 0.0.0.0, time stamp: 0x00000000
Exception code: 0xc0000005
Fault offset: 0x043cd682
Faulting process ID: 0x26c
Faulting application start time: 0x01d0faf38a7b80e6
Faulting application path: D:\HomeSeer HS3\HSPI_FitbitSeer.exe
Faulting module path: unknown
Report ID: 7a17d1b2-729d-11e5-974c-00606ea565f6
Faulting package full name:
Faulting package-relative application ID:
Hmmm! That is strange, what happens if you restart the plugin manually (disable and then enable it)?
Could it be Fitbit that is having problems? I'm not seeing any issues here in Europe.
