When I click on the "Get Withings Auth Code" in the plugin config I am taken to a withings page to grant access to the plugin. After logging in, selecting a user, and granting access a page opens that starts with https://connected2.homeseer.com with my myhs token, and a code in the URL. This page has the title Withings WebHook, and shows the HS3 navigation bar, but is blank otherwise. At this point I do not know what to do. The plugin does not seem to be able to access withings yet at this stage, and it is not able to connect/Create Devices.
Unable to get Withings Auth Code
_______________________________________________
HS3 : HSpro (3.0.0.460) on Win2012 (vm on ESXi)
Plugins: HSTouch, UPBSpud, Kinect, Nest, IFTTT, DirecTV, EasyTrigger, Imperihome, Zwave, RFXcom, UltraMon3, UltraWeatherBug3, UltraGCIR3, UltraLog3, UltraPioneer, PHLocation, Pushover, Pushalot, MCSSPrinklers S, JowiHue
Jon00 Plugins: Bluetooth Proximity, Performance Monitor, DB Chart, LinksTags: None
Originally posted by jlrichar View PostWhen I click on the "Get Withings Auth Code" in the plugin config I am taken to a withings page to grant access to the plugin. After logging in, selecting a user, and granting access a page opens that starts with https://connected2.homeseer.com with my myhs token, and a code in the URL. This page has the title Withings WebHook, and shows the HS3 navigation bar, but is blank otherwise. At this point I do not know what to do. The plugin does not seem to be able to access withings yet at this stage, and it is not able to connect/Create Devices.
Doh. I replied last night then closed my browser, and now I do not see my reply in this thread. I guess the board logged me off before I replied. At any rate the withings auth worked on the second try after I read your response. I was able to connect/create devices- and they work. I’m using Chrome BTW.
One disappointment was finding out the sleep sensor does not have a bed occupancy type of function with the plugin. I believe this is possible with IFTTT. Any chance you can add this? I’d like to use bed occupancy as a trigger/condition, and don’t want to rely on the current homeseer/IFTTT connection. It’s actually my main interest in this plugin.
Sent from my iPhone using Tapatalk Pro_______________________________________________
Originally posted by jlrichar View PostDoh. I replied last night then closed my browser, and now I do not see my reply in this thread. I guess the board logged me off before I replied. At any rate the withings auth worked on the second try after I read your response. I was able to connect/create devices- and they work. I’m using Chrome BTW.
2. Yes there is the IFTTT occupancy which works rather well. No I can't integrate it yet. I have been pushing them to open that portion of the API and I'm hoping they will but I don't have any kind of ETA on it.
