HS4 and withings
  • wkrasner
    Thank you Frank, Let me know, so I can pursue a refund from Homeseer
  • sirmeili
    I'm still working on it, but please note that ny work I do will not guarantee it will work on HS4 as I have done zero testing for any of my plugins on HS4 and don't plan to in the near future. I will get a beta out in the next week or two, but it will likely require that people completely re-install.
  • wkrasner
    Frank,
    Any progress. Thanks
    Will
  • CrashnBrn
    I just found this plugin, but I'm currently running HS4. As soon as the patch is out I'll be purchasing. So I'm looking forward to it. Thank you!
  • sirmeili
    I have one, so yes, if I don't have it in there, I will, add it. I'm 99.9% sure it's already accounted for.
  • DaleRS
    will the re-write/hs4 look at the blood pressure cuff? I am interested in the app. Thanks
  • wkrasner
    Frank,
    I appreciate you diving in. Let me know and I will give it a go.
    Will
  • sirmeili
    I have a completely written version (still HS3) that I'll try and tidy up over the next few days while I'm on a bunch of deployment calls. I think I have at least 90% of the functionality there, the only issue is that there is no "upgrade path" from the old version, it's a completely uninstall, reinstall, which I'm trying to get around.
  • wkrasner
    started a topic HS4 and withings
    HS4 and withings
    Good morning. I just upgraded to HS4 and cannot get Withings to work. The command window on the HS4 server for withings reports "invalid toke" then exceptions out (see attached screen capture)
    [ATTACH=CONFIG]n1405099[/ATTACH]
    The following is teh system log:
    8/03/2020 13:16:01
    HomeSeer
    Info
    Plugin Withings with ID: and Instance: has disconnected
    8/03/2020 13:15:33
    HomeSeer
    Starting Plug-In
    Plugin Withings started successfully in 2634 milliseconds
    8/03/2020 13:15:33
    Legacy-Plugin
    Withings ERROR
    Exception CheckAndCreateDevices(): System.ArgumentNullException: Value cannot be null. Parameter name: value at Newtonsoft.Json.JsonConvert.DeserializeObject(String value, Type type, JsonSerializerSettings settings) at Newtonsoft.Json.JsonConvert.DeserializeObject[T](String value, JsonSerializerSettings settings) at Newtonsoft.Json.JsonConvert.DeserializeObject[T](String value) at HSPI_Withings.Plugin.UpdateAllDevices() at HSPI_Withings.Plugin.CheckAndCreateDevices()
    8/03/2020 13:15:32
    Legacy-Plugin
    Withings Debug
    Withings Device Key: 28850754cf659952b281127072a72dd7b5ba356b_battery HS3 devRef: 2161
    8/03/2020 13:15:32
    Legacy-Plugin
    Withings Debug
    Withings Device Key: 28850754cf659952b281127072a72dd7b5ba356b_root HS3 devRef: 2160
    8/03/2020 13:15:32
    Legacy-Plugin
    Withings Debug
    Withings Device Key: 20344268_totalcalories HS3 devRef: 2134
    8/03/2020 13:15:32
    Legacy-Plugin
    Withings Debug
    Withings Device Key: 20344268_calories HS3 devRef: 2133
    8/03/2020 13:15:32
    Legacy-Plugin
    Withings Debug
    Withings Device Key: 20344268_active HS3 devRef: 2132
    8/03/2020 13:15:32
    Legacy-Plugin
    Withings Debug
    Withings Device Key: 20344268_intense HS3 devRef: 2131
    8/03/2020 13:15:32
    Legacy-Plugin
    Withings Debug
    Withings Device Key: 20344268_moderate HS3 devRef: 2130
    8/03/2020 13:15:32
    Legacy-Plugin
    Withings Debug
    Withings Device Key: 20344268_soft HS3 devRef: 2129
    8/03/2020 13:15:32
    Legacy-Plugin
    Withings Debug
    Withings Device Key: 20344268_elevation HS3 devRef: 2128
    8/03/2020 13:15:32
    Legacy-Plugin
    Withings Debug
    Withings Device Key: 20344268_distance HS3 devRef: 2127
    8/03/2020 13:15:32
    Legacy-Plugin
    Withings Debug
    Withings Device Key: 20344268_steps HS3 devRef: 2126
    8/03/2020 13:15:32
    Legacy-Plugin
    Withings Debug
    Withings Device Key: 20344268_11 HS3 devRef: 1193
    8/03/2020 13:15:32
    Legacy-Plugin
    Withings Debug
    Withings Device Key: 20344268_10 HS3 devRef: 1192
    8/03/2020 13:15:32
    Legacy-Plugin
    Withings Debug
    Withings Device Key: 20344268_9 HS3 devRef: 1191
    8/03/2020 13:15:32
    Legacy-Plugin
    Withings Debug
    Withings Device Key: 5ab27c6b9d8e4a08f7e0a835c4288de378ba573e_battery HS3 devRef: 2122
    8/03/2020 13:15:32
    Legacy-Plugin
    Withings Debug
    Withings Device Key: 5ab27c6b9d8e4a08f7e0a835c4288de378ba573e_root HS3 devRef: 2121
    8/03/2020 13:15:32
    Legacy-Plugin
    Withings Debug
    Withings Device Key: 20344268_5 HS3 devRef: 1186
    8/03/2020 13:15:32
    Legacy-Plugin
    Withings Debug
    Withings Device Key: 20344268_6 HS3 devRef: 1185
    8/03/2020 13:15:32
    Legacy-Plugin
    Withings Debug
    Withings Device Key: 20344268_88 HS3 devRef: 1184
    8/03/2020 13:15:32
    Legacy-Plugin
    Withings Debug
    Withings Device Key: 20344268_77 HS3 devRef: 1183
    8/03/2020 13:15:32
    Legacy-Plugin
    Withings Debug
    Withings Device Key: 20344268_76 HS3 devRef: 1182
    8/03/2020 13:15:32
    Legacy-Plugin
    Withings Debug
    Withings Device Key: 20344268_8 HS3 devRef: 1181
    8/03/2020 13:15:32
    Legacy-Plugin
    Withings Debug
    Withings Device Key: 20344268_4 HS3 devRef: 1180
    8/03/2020 13:15:32
    Legacy-Plugin
    Withings Debug
    Withings Device Key: 20344268_1 HS3 devRef: 1179
    8/03/2020 13:15:32
    Legacy-Plugin
    Withings Debug
    Withings Device Key: 20344268_root HS3 devRef: 2125
    8/03/2020 13:15:32
    Legacy-Plugin
    Withings Debug
    Withings Device Key: fd39c60df8715bc71acc59fe0f41c40606f0ea9e_battery HS3 devRef: 2124
    8/03/2020 13:15:32
    Legacy-Plugin
    Withings Debug
    Withings Device Key: fd39c60df8715bc71acc59fe0f41c40606f0ea9e_root HS3 devRef: 2123
    8/03/2020 13:15:30
    HomeSeer
    Starting Plug-In
    Initializing plugin Withings ...
    8/03/2020 13:15:30
    HomeSeer
    Starting Plug-In
    Withings loaded in 15010 milliseconds
    8/03/2020 13:15:15
    HomeSeer
    Info
    Plugin Withings has connected. IP:127.0.0.1:55900
    Will
