Withings version 3.0.1.42 (Beta) is now available!
    Withings v3.0.1.42 is now available in the HomeSeer store and in the updater (Beta Section)!
    Please consider this more like an Alpha. A lot has changed since the non-beta version. I have done some testing of upgrading from that version and all my tests worked, but please back up your install before or be prepared to re-install the Withings plugin from scratch.
    Please install at your own risk. That being said, I could really use some testers for this, especially the bed notifications.
    Also note that I think there was a 3.0.1.41 version in the beta section. I don't have access to that version so was unable to test update scenarios for that version.
    The following are included:
    • This is almost a complete rewrite of the plugin code.
    • Utilizes Real time Updates from Withings API (instead of polling, though polling is left in as a backup)
    • In/Out Bed Triggers have been added*
      • I saw a response time between 5 and 10 seconds, but the API does say it can take up to 2 minutes. I've never seen it take that long though.
    • Configurations have been reformatted.
      • Plugin should update to the new format, but I've only been able to test my local setup.
    • Some settings have been changed to per user basis instead of all or nothing.
    • Added Thermometer as a separate group of devices to get updates for.
    • Added settings to chose the scale for each data type instead of metric or imperial only.
    • Probably more that I'm forgetting.
    MeiAutomtion Home
    Please note that if you have a previously authorized user and you let the plugin "update" your settings, you have to re-authorize the user in order for Bed In/Out notifications to work. Nothing else will change except that you give Withings your approval for me to set notification call backs for sleep notifications.
    This means your existing devices will still be there and not changed.
    Also, Bed in/out notifications are "triggers" in Events and not reflected anywhere else. I could possibly make them a device to denote if that person is in a bed or not. Thoughts?
    MeiAutomtion Home
      I can test but I'm running HS4 now exclusively. Is your plugin compatible? I have the scale, watches, and bed sensors.
      Devan
        It would nice to have "In Bed" as a device to easily integrate node-red.
          I would agree. I would like to see it show as In Bed as a Device.
            I haven't yet been able to create devices to play around with the plugin. But I do have a question; does the app allow you to connect more than one Withings account? My wife has her own account.
            HS4 Pro on Shuttle NC10U, Win10; Z-NET
            Number of Devices: 449
            Number of Events: 210
            Plug-Ins: Arduino, BLLock, DirecTv, EasyTrigger, Honeywell WiFi Thermostat, MeiHarmonyHub, PHLocation2, Pushover 3P, UltraM1G3, WeatherXML, Worx Landroid, Z-Wave
            External applications: Homebridge-homeseer, Geofency, EgiGeoZone.
              After a bit of research, I think the best solution in my case is to have my wife delete her account and then add her as a family member on mine. That way only one account needs to be connected.
                I am actually having issues with the triggers for in and out bed. They don't seem to be executing.
                  This is how my wife and I do ours.
                  MeiAutomtion Home
                    I'll add some logging tonight.
                    MeiAutomtion Home
                      It occurred to me that some more information on the error I see when I try to authenticate the plugin on the Withings website might be useful
                      Using the beta of course 3.0.1.42, Win 10, chrome, HS4. I have two Withings devices, both Sleep. Two withings users. When I first tried to use the Beta I just had one Sleep and user. I do have a scale on order.
                      I'm not sure how the myhs access code or token is supposed top display. Initially I used "request access code/pin" I put the code in the pop up dialog window "paste here". It remains in that box until I leave the config page. If I go to the config page later this is blank and no line is shown below it next to the myhs token line.
                      I thought that perhaps there was a bug here that wasn't saving the access code so I downloaded MyHSToken. MyHSToken saves the token just fine and it's displayed as one would expect. The Withings config still doesn't show one however.
                      The error I see on the withings site when I click Allow this App is:
                      {"errors":[{"message":"redirect_uri_mismatch: The redirect URI provided is missing or does not match partner callback url"}]}
                      I am unable to connect/create any Withings devices
                        after you put the "Pin" in the box, ther is a box to request the myHS token, you have to click that in order to get your myHS token. It's a 2 step process. Once it has the token, it should be saved.
                        MeiAutomtion Home
                          I disabled MyHSToken and manually obtained a token, thank you so much.
                          Able to connect to Withings and create devices.
                          Although the plugin did ignore the updated default location 1 and 2 I had put in.
                          Also only one of the 2 users on my Withings account is listed. This may be why only one of the two sleep devices had HS devices created?
                          While I have created a profile for her and populated it, we had to wait the 7 day period after removing her other account before I could invite her. I'll invite her to log in tomorrow.
                            I will check that the plugin is using the locations correctly.
                            Note that you need to authorize with withings for each user on your account that you want to monitor.
                            When you authorize, withings should ask which one you want to authorize for.
                            MeiAutomtion Home
                              Thank you! Unable to locate your help files maybe post a PDF to the forums?
