I was able to get version 3.0.1.43 to install and configure eventually, but I am not seeing any updates to the out of bed status. How can I help troubleshoot this?
Out of Bed Status Not Updating
1) I assume you have myHS set up, is this correct?
2) Did you update from an older version of the plugin? If so, go back and re-authorize the plugin. It needs an extra permission from Withings to get bed notifications.
2). because you have the icon, my guess is you still have the "Bed Notifications" checked?
Originally posted by sirmeili View Post1) I assume you have myHS set up, is this correct?
It would not let me authorize with Withings until this was done. It would give this error until I got the HS token:
{"errors":[{"message":"redirect_uri_mismatch: The redirect URI provided is missing or does not match partner callback url"}]}
Originally posted by sirmeili View Post1) 2) Did you update from an older version of the plugin? If so, go back and re-authorize the plugin. It needs an extra permission from Withings to get bed notifications.
Originally posted by sirmeili View Post1) 2). because you have the icon, my guess is you still have the "Bed Notifications" checked?
Originally posted by jmedemar View PostI did perform the process to get the HS token that used to be at the top of the setup page.
No, This is the first and only install of the plugin. I have authorized with Withings multiple times for both users on the account trying to make it function.
Yes, I have Sleep and In/Out Bed Notifications checked currently.
Ok, if you can turn on debug logging and get in/out of bed a few times then send me the logs I can see if it's getting the messages. Note that it takes up to 10 seconds in my experience to get the notification. It's not Instant.
I then enabled the plugin and it recreated the Aura Sensor V2 Sleep Monitor and battery devices. I then changed the user names, checked only box next to In/Out Bed notifications and clicked the Connect/Create devices button. The log is attached. It did not create any new devices, just logged some errors.
I unchecked all boxes in the plugin settings, disabled the plugin, deleted all the devices it had created, reinstalled via the beta menu, then turned on debug logging (=True) in config file.
Note that in the log it will have your accessToken from Withings and your myHSToken as well. You can clean those out when you post the logs, but I need to know if they have actual values or if they are null. I can't reproduce your issues so something is set to null and I need to figure out what that is.
I put a version with a lot of debug code in it. It's in the beta section Can you try and run it? It's 3.0.1.44.
