Installed the plug-in today from the HS3 updater. Got my HS code and token and believe I created two Withings authorization codes. (I got as far as a HS window with the address of "https://connected2.homeseer.com/WithingsWebHook?token=XXXXXXXXXXXXXXXXXX&code=YYYYYYYYYYYYYY YYYYYYYYYYYYYYYYYYY&state=HSPI_Withings" but I believe that is alright because Withings-users file was updated with these codes......)
So now all that happens every hour on the hour is the creation of two (more) devices. Battery and Scale. For most of the day it did not update the device. Starting at 7pm tonight, the new Battery device was created with and updated with what I think is the battery status? Additionally, in the log there is an error. I can't make heads or tails of it. How close am I? How do I get past this?
Mar-08 20:00:23 | Starting Plug-In | Plugin Withings started successfully in 2973 milliseconds |
Mar-08 20:00:23 | Withings ERROR | Exception CheckAndCreateDevices(): Newtonsoft.Json.JsonReaderException: JSON integer 2557521700 is too large or small for an Int32. Path 'body.measuregrps[0].grpid', line 1, position 108. at Newtonsoft.Json.JsonTextReader.ParseReadNumber(ReadType readType, Char firstChar, Int32 initialPosition) at Newtonsoft.Json.JsonTextReader.ParseNumber(ReadType readType) at Newtonsoft.Json.JsonTextReader.ReadNumberValue(ReadType readType) at Newtonsoft.Json.JsonTextReader.ReadAsInt32() at Newtonsoft.Json.JsonReader.ReadForType(JsonContract contract, Boolean hasConverter) at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.P opulateObject(Object newObject, JsonReader reader, JsonObjectContract contract, JsonProperty member, String id) at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.C reateObject(JsonReader reader, Type objectType, JsonContract contract, JsonProperty member, JsonContainerContract containerContract, JsonProperty containerMember, Object existingValue) at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.C reateValueInternal(JsonReader reader, Type objectType, JsonContract contract, JsonProperty member, JsonContainerContract containerContract, JsonProperty containerMember, Object existingValue) at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.P opulateList(IList list, JsonReader reader, JsonArrayContract contract, JsonProperty containerProperty, String id) at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.C reateList(JsonReader reader, Type objectType, JsonContract contract, JsonProperty member, Object existingValue, String id) at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.C reateValueInternal(JsonReader reader, Type objectType, JsonContract contract, JsonProperty member, JsonContainerContract containerContract, JsonProperty containerMember, Object existingValue) at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.S etPropertyValue(JsonProperty property, JsonConverter propertyConverter, JsonContainerContract containerContract, JsonProperty containerProperty, JsonReader reader, Object target) at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.P opulateObject(Object newObject, JsonReader reader, JsonObjectContract contract, JsonProperty member, String id) at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.C reateObject(JsonReader reader, Type objectType, JsonContract contract, JsonProperty member, JsonContainerContract containerContract, JsonProperty containerMember, Object existingValue) at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.C reateValueInternal(JsonReader reader, Type objectType, JsonContract contract, JsonProperty member, JsonContainerContract containerContract, JsonProperty containerMember, Object existingValue) at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.S etPropertyValue(JsonProperty property, JsonConverter propertyConverter, JsonContainerContract containerContract, JsonProperty containerProperty, JsonReader reader, Object target) at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.P opulateObject(Object newObject, JsonReader reader, JsonObjectContract contract, JsonProperty member, String id) at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.C reateObject(JsonReader reader, Type objectType, JsonContract contract, JsonProperty member, JsonContainerContract containerContract, JsonProperty containerMember, Object existingValue) at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.C reateValueInternal(JsonReader reader, Type objectType, JsonContract contract, JsonProperty member, JsonContainerContract containerContract, JsonProperty containerMember, Object existingValue) at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.D eserialize(JsonReader reader, Type objectType, Boolean checkAdditionalContent) at Newtonsoft.Json.JsonSerializer.DeserializeInternal(JsonReade r reader, Type objectType) at Newtonsoft.Json.JsonConvert.DeserializeObject(String value, Type type, JsonSerializerSettings settings) at Newtonsoft.Json.JsonConvert.DeserializeObject[T](String value, JsonSerializerSettings settings) at Newtonsoft.Json.JsonConvert.DeserializeObject[T](String value) at HSPI_Withings.Plugin.CheckAndCreateDevices() |
Mar-08 20:00:22 | Withings Debug | Created: 2173 Battery |
Mar-08 20:00:22 | Withings Debug | Created: 2172 Body+ Scale |
Mar-08 20:00:22 | Withings Debug | Refreshing Token for User: |
Mar-08 20:00:21 | Withings Debug | Refreshing Token for User: e25913ea066c570b6bed8c1a42c639eee3460daf |
Mar-08 20:00:21 | Withings Debug | Refreshing Token for User: 758bb773ebcae7b480d7897596513fd60df6fdbc |
Mar-08 20:00:20 | Starting Plug-In | Initializing plugin Withings ... |
Mar-08 20:00:20 | Starting Plug-In | Withings loaded in 15094 milliseconds |
Mar-08 20:00:05 | Info | Plugin Withings has connected. IP:127.0.0.1:61677 |
Mar-08 20:00:04 | Warning | I/O interface Withings is down, executable is not running, restarting ... |
Mar-08 20:00:03 | Info | Plugin Withings with instance: has disconnected |
Mar-08 20:00:03 | Withings Debug | Refreshing Token for User: 5cc6cff30fe613b0ebc35d9d890f0bfa25f28f92 |
Mar-08 19:49:49 | Z-Wave | 2 out of 2 Child devices of node 184 were created successfully. |
