Alexa Push Notification
  • #16
    i think being able to pass audible notifications would be a sweet feature.
    • #17
      Looks like Amazon is working on something:
      Hopefully HomeSeer is signed up to get the 411 when Amazon releases it to developers...
      • #18
        Are homeseer working on this as i now believe amazon have included this feature ?
        • #19
          +1 that would be fantastic.
          Sent from my SM-G935V using Tapatalk
          • #20
            Are you speculating or have you actually seen the API or the feature documented? I will admit that I do not check daily, but to my knowledge as of a month or so ago this was not possible as I did not come across the api.
            Maybe I missed it....
            • #21
              I didn't look any further than a comment I read else where but this the on the developer portal.
              https://developer.amazon.com/docs/al...-overview.html
              • #22
                You can push notifications to your Alexa with the Notify Me skill (https://amzn.to/2DOsuor). It won't speak your message aloud without prompting, but it does make a "bing" noise and illuminate the LED ring to let you know you have a message.
                You can learn more about it at www.notifymyecho.com. The VB script I've successfully used with HS3 running on a RPi3 is as follows (you pass your message as a parameter to the script):
                Sub Main(ByVal notification As String)
                  dim accessCode = "ACCESS_CODE"
                  dim host = "https://api.notifymyecho.com"
                  dim path = "/v1/NotifyMe?notification="+notification+"&accessCode="+accessCode
                  dim result = hs.GetURL(host, path, TRUE, 443)
                  hs.WriteLog("msg", result)
                End Sub
                Before you can use this, you must first enable the Notify Me skill and then replace the ACCESS_CODE string in the script with the one the Notify Me skill emails you.
                • #23
                  Thank you, it worked like a charm.
                  End Sub
                  • #24
                    Glad to hear. I'm still finding crazy uses for notifications, not all practical, of course. ;-)
                    • #25
                      I'm a little surprised because I expecting to have to modify the script to convert spaces into %20 since the parameter text is being passed as a URL.
                      Very nice... Thanks for sharing.
                      End Sub
                      ~Bill
                      • #26
                        Thanks but do you place the script in your script folder or put it in the sub or function part of an event
                        • #27
                          I saved the script in my script folder (you then later have to select it as the script you want to run, of course). I left the Sub or Function box blank so it would, by default, call the Sub Main part of the script. Put your message in the Parameters box.
                          -Randy
                          • #28
                            Thanks, that worked. lots of little possibilities for this guy.
