Alexa reports temp in Celsius
    So this has been happening for a while now , when I ask for the stat temp it says "23 degress"... it saying the temp in Celsius where my settings are in farenheit.. Anyone found a cure for this??
    Hector
    Win.2003 OS, HS3
    MyTrigger,ACRF2,W800,Zwave
    AP800,Honeywell Stat
    Did you try Googling this? A quick search shows the exact steps to change this.
    -Rupp
      Rupp, if you are referring to the settings on the app, that has been checked , the app is enabled for farenheit.
      Hector
      Win.2003 OS, HS3
        Which stat are you using? Do you have F selected on your Tools > Setup > General Tab > Temperature Scale?
        -Rupp
          Same here. My thermostat is connected to the ElkM1g and interfaced to HS via the ElkM1G Ultra plugin. It worked a while back but from the last year or so it reports house temp in celsius. There are some other threads where this was discussed. It is not the Alexa app settings. Something happened in the HS side of the skill that seems to cause some thermostats to do this and report temps in Celsius.
            Same here with CT-100 thermostats. Reports in Celsius.
            Michael
              All my setting are correct.. as it been said, this is a HS skill issue, I hope the people in HS can take a look at this, it's easy to reproduce just ask alexa to get stat temp..
              Hector
              Win.2003 OS, HS3
                I just tested this here and it's working just fine. Which skill are you using? Have you tried removing the stat and adding it back to your network?
                -Rupp
                  I am using the smart home skill, how do I know if there a update to the skill..?
                  Hector
                  Win.2003 OS, HS3
                    If there's an update it will be automatically picked up as changes are dynamic. I would recommend using the remove/delete a node from within the Z-Wave controller management and then add the stat back to HS3 and this should fix this.
                    -Rupp
                      This is still not fixed. Alexa is set up for
                      Fahrenheit. Homeseer Temperature Scale is Fahrenheit. Trane Zwave thermostat has been removed and readded, still reports temperature as 23.9 degrees.
                        I've recently upgraded to HS4 and enabled Alexa. It's still broken.
                          The HomeSeer team has been updating the Skill (with this fix) and said it is close to being pushed to production, but you will need to have HS4. I hope they will notify the community with the news and any new capabilities. I am waiting for the announcement before I upgrade to HS4.
                            Been waiting for this for the longest time, now for it to work you need to upgrade, that not right...
                            Hector
                            Win.2003 OS, HS3
                              Ditto here. Alexa is reporting in Celsius. After Alexa reports the Celsius I ask Alexa to convert the Celsus to Farhenheight to get the correct temp. Very annoying.
