Homeseer Home Automation is GONE. Nothing is working any more that I used to use. I have Jon00Alexa.ini with a handful of routines as well as events in HS4 that dont work at all now. Is there some other way to make this all work?
You would need to chase HST then. I very much doubt they would look here (edit: moved to the correct forum).
It may be possible to create your own skill but I don't know if the following still works: https://forums.homeseer.com/forum/3r...34#post1290908
We are working with Amazon to get it back. Note that this is the "tell homeseer" skill. Amazon appears to be reviewing skills and they ran a test on ours and it failed. It does not abide by their current rules because we simply take the phrase the user said and pass it to HS. That is no longer allowed but they grandfathered us in last year. So we are arguing the case with them. I can post back here when I hear back. I pinged them again today.
If you have it enabled, you can still use it, so DO NOT disable it! If you did disable it, you will have to wait and see what happens.
Note that our Smart Home Skill is still available.
- 3 likes
Originally posted by TC1 View Post
Just curious... why are you "slowly rewriting my whole system", whatever that means?
Originally posted by NET1 View Post
Not OP but Alexa rebuilds are painful. Sometimes have to add one device at a time, go through Alexa discovery, turn another device on for voice control in HS, go through Alexa discovery again, etc. All of my routines are set up HomeSeer-side (as they should be) because Alexa (not necessarily the HomeSeer integration portion) is fairly unreliable.
